Redshift FAQ article development
In summary, the article covers the different types of redshift, how they're different, and what they mean. It also discusses Hubble's law and the cosmological constant.
  • #36
I'm not sure you're going to like all of this, but here is my take, trying to change as little as possible:
Mordred said:
EXPANSION AND REDSHIFT
1) Why is all the galaxies accelerating from us ?
is -> are
Mordred said:
2) Is Redshift the same as Dopplershift ?
3) What is causing the expansion of the Universe ?
4) Is Expansion, faster than light in parts of the Universe, and How does this not violate the faster than light speed limit ?
5) What is a Cepheid or standard candle ?
6) What do we mean when we say Homogeneous and Isotropic ?
7) How do we measure the distance to Galaxies ?
8) What is outside the Universe?
9) What do we mean when an object leaves our universe ?These are some of the common questions I will attempt to address in the following article
First we must define some terms and symbols used.
Planck constant: [itex]h\ =\ 6.62606876(52)\ \times\ 10^{-34}\ J\ s[/itex]
Gravitational constant: [itex]G\ =\ 6.673(10)\ \times\ 10^{-11}\ m^{3} kg^{-1} s^{-2}[/itex]
Speed of light in a vacuum:[itex]c\ =\ 2.99792458\ \times\ 10^{8}\ m\ s^{-1}[/itex]
Universe: The Universe in cosmology is defined as the Observable Universe The observable universe from Earth is 46 Billion light years, or 4.3×1026meters with an age as of 2013, is 13.772 ± 0.059 billion years. So how do we see farther than 13.772 billion years, the answer lies in expansion. As light is traveling towards us, spacetime has expanded.
One common Question posters often ask is " What is outside our Universe, this question has no meaning as without space or time you have nonexistence. Also their is no clear consensus on if the Universe is Finite or Infinite. " When an object is said to leave our universe" we mean that the object has crossed the observable universe or rather that it is redshifted to the point of non detectable.The parsec (symbol: pc) is a unit of length used in astronomy, equal to about 30.9 trillion kilometres(19.2 trillion miles). In astronomical terms, it is equal to 3.26 light-years, and in scientific terms it is equal to 3.09×1013 kilometres
Mpc=1 million Parsecs
In order to understand Redshift we must first need to distinquish the between RedShift and Doppler shift. In both cases the light emitted by one body and received by the other will be Red/Blue shifted ie its wavelength will be stretched. So the color of the light is more towards the red/blue end of the spectrum. As shown by the relation formula below. But there's a subtle difference, between Dobblershift and redshift.
Replace the above paragraph with:
Doppler shift and redshift are the same phenomenon in general relativity. Often, however, you will see Doppler factored into components with different names used, as will be explained below. In all cases of Doppler, the light emitted by one body and received by the other will be Red/Blue shifted ie its wavelength will be stretched. So the color of the light is more towards the red/blue end of the spectrum. As shown by the formula below.
Mordred said:
[tex]\frac{\Delta_f}{f} = \frac{\lambda}{\lambda_o} = \frac{v}{c}=\frac{E_o}{E}=\frac{hc}{\lambda_o} \frac{\lambda}{hc}[/tex]
The Doppler Redshift results from the relative motion of the light emitting object and the observer. If the source of light is moving away from you then the wavelength of the light is stretched out, i.e., the light is shifted towards the red. When the wavelength is compressed from an object moving towards you then it moved towards the blue end of th spectrum. These effects, individually called the blueshift, and the redshift are together known as doppler shifts. The shift in the wavelength is given by a simple formula
(Observed wavelength - Rest wavelength)/(Rest wavelength) = (v/c)
[tex] f=\frac{c+v_r}{c+v_s}f_o[/tex]
c=velocity of waves in medium
[tex]v_r[/tex] is velocity of the reciever to the medium (positive if moving toward the source, negative if moving away)
[tex]v_s[/tex] is the velocity of the source to the medium (positive if moving away from the reciever, negative if other direction)
The above are for velocities where the source is directly away or towards the observer and for low velocities less than relativistic velocities. A relativistic doppler formula is required when velocity is comparable to the speed of light. Their are different variations of the above formula for Tansverse Doppler shift or other angles.
Doppler shift is used to describe Redshift due to inertial velocity one example is a car moving away from you the light will be Red Shifted, as it approaches you the light and sound will be blueshifted.
Add here:
In general relativity and cosmology, there is a fundamental complication in this simple picture - relative velocity cannot be defined uniquely over large distances. However, it does become unique when compared along the path of light. With relative velocity compared along the path of the light, the special relativity Doppler formula describes redhsift for all situations in general relativity and cosmology. It is important to realize that gravity and expansion of the universe affect light paths, and how emitter velocity information is carried along a light path; thus gravity and expansion contribute to Doppler redshift.
Mordred said:
The Cosmological Redshift is however a redshift caused by the expansion of space. The wavelength of light increases as it traverses the expanding universe between its point of emission and its point of detection by the same amount that space has expanded during the crossing time indeed the amount of redshift is the total amount of expansion. This is a measure of its recessive velocity over DISTANCE. The further away an object is the greater the amount of RedShift. This is given in accordance with Hubbles Law. In order to quantify the velocity of this galactic movement, Hubble proposed Hubble's Law of Cosmic Expansion, aka Hubble's law, an equation that states:
Replace above paragraph with:
The Cosmological Redshift is a redhsift attributed to the expansion of space. The expansion causes a recession velocity for galaxies (on average) that is proportional to DISTANCE. This recession velocity then produces a Doppler (red) shift proportional to distance (please note that this recession velocity must be converted to a relative velocity along the light path before it can be used in the Doppler formula). The further away an object is the greater the amount of RedShift. This is given in accordance with Hubbles Law. In order to quantify the velocity of this galactic movement, Hubble proposed Hubble's Law of Cosmic Expansion, aka Hubble's law, an equation that states:
Mordred said:
Hubbles Law: The greater the distance of measurement the greater the recessive velocity
velocity = H0 × distance.
Velocity represents the galaxy's recessive velocity; H0 is the Hubble constant, or parameter that indicates the rate at which the universe is expanding; and distance is the galaxy's distance from the one with which it's being compared.
The Hubble Constant has been calculated at different values over time, this is essential as the rate of expansion varies over time but the current accepted value is 70 kilometers/second per megaparsec, or Mpc. The latter being a unit of distance in intergalactic space described above.
Any measurement of redshift above the Hubble distance defined as c=H0 = 4300±400 Mpc will have a recessive velocity of greater than the speed of light. This does not violate GR for a couple of reasons.
1) Recessive velocity is distance dependant
2) Recessive velocity is not inertial velocity, the galaxies are not accelerating from us, the SPACE between us and the galaxy is increasing.
Delete the two bullets above and replace the last sentence of the prior paragraph with:
This does not violate GR because a recession velocity is not a relative velocity. It is precisely analogous to a separation speed. If, in one frame of reference, one object is moving East at .9c, and another West at .9c, they are separating by 1.8c. This is their recession velocity. Their relative velocity remains less than c. In cosmology, two things change from this simple picture: expansion can cause separation speeds much greater even than 2c; and relative velocity is not unique, but no matter what path it is compared along, it is always less than c, as expected.
Mordred said:
This is given by the form.
formula
Mordred said:
z = (Observed wavelength - Rest wavelength)/(Rest wavelength) or more accurately
1+z= λobservedemitted or z=(λobservedemitted)/λemitted
[tex]1+Z=\frac{\lambda}{\lambda_o}[/tex] or [tex]1+Z=\frac{\lambda-\lambda_o}{\lambda_o}[/tex]
λ0= rest wavelength
Note that positive values of z correspond to increased wavelengths (redshifts).
Strictly speaking, when z < 0, this quantity is called a blueshift, rather than
a redshift. However, the vast majority of galaxies have z > 0. One notable blueshift example is the Andromeda Galaxy, which is gravitationally bound and approaching the Milky way.
WMAP nine-year results give the redshift of photon decoupling as z=1091.64 ± 0.47 So if the matter that originally emitted the oldest CMBR photons has a present distance of 46 billion light years, then at the time of decoupling when the photons were originally emitted, the distance would have been only about 42 million light-years away. Cosmological Redshift is distance dependant as mentioned above, if you were to teleport to the other side of the galaxy where you measured that greater than light recessive velocity, you would find the same expansion rate as your original location relative to an equal distance. Indeed expansion occurs the same throughout the cosmos. However Gravity and the strong Nuclear force in Galaxy clusters are strong enough to prevent expansion. In other words galaxy clusters are gravitationally bound.
In regards to expansion it is important to realize that galaxies are not moving from us due to inertia, rather the space between between two coordinates are expanding. This is important in that no FORCE is acting upon the galaxies to cause expansion. That expansion is homogeneous and isotropic. In other words, there is no preferred location (Homogeneous) and no preferred direction (Isotropic). Keep in mind these terms describe the universe on large scales. Indeed below 100 Mpc we know that galaxy clusters, large scale clusters are not homogeneous or isotropic.
As expansion is homogeneous and isotropic then there is no difference in expansion at one location or another. In the LambdaCDM model expansion is attributed to the cosmological constant.
Cosmological Constant is a homogeneous energy density that causes the expansion of the universe to accelerate. Originally proposed early in the development of general relativity in order to allow a static universe solution it was subsequently abandoned when the universe was found to be expanding.
Now the cosmological constant is invoked to explain the observed acceleration of the expansion of the universe. The cosmological constant is the simplest realization of dark energy, which is the more generic name given to the unknown cause of the acceleration of the universe. Indeed what we term as "Dark" energy is an unknown energy that comprises most of the energy density of our cosmos around 73%. However the amount of dark energy per M3 is quite small some estimates are around about 6 × 10-10 joules per cubic meter. However their is a lot of space between Large scale clusters, so that small amount per M3 adds up to a significant amount of energy in total
Another term often used for the cosmological constant is vacuum energy described originally by the false vacuum inflationary Model by A.Guth. The cosmological constant uses the symbol [itex]\Lambda[/itex]. the greek letter Lambda.
This False vacuum inflationary model is one that describes a total energy balance of zero, where gravity is the negative energy. In this model what we term as "Nothing " is really a quantum vacuum with quantum fluctuations described by the Heisenburg uncertainty principle. Virtual particles pop in and out of existence all the time, As expansion occurs those virtual particles Quantum tunnel between the false vacuum and the true vacuum, becoming real particles. The full explanation is a little more involved than this quick explanation however this model is often referred to as a "Universe from Nothing" or the "Ultimate free lunch" . Many of our current inflationary models has its roots in this model.
have their roots
Mordred said:
However one fundamental problem with all inflationary models is "Runaway expansion" Once the process starts no one has found a mechanism to stop expansion.
One means of relating to expansion is with the use of the a grid of squares. each
capitalize: Each
Mordred said:
horizontal and vertical crossing on that grid is a coordinate. In expansion the space between all coordinates not gravitationally bound expand equally. In other words te
te -> the
Mordred said:
coordinates do not change, the space between coordinates change. I should also note their is no clear consensus on whether the universe is finite or infinite. If its infinite now then it was infinite in the past. Same with Finite. The Big Bang model only describes the Universe from 10-43 seconds and is not considered as starting from a black hole singularity, rather its properly described as a rapid expansion of spacetime.
WMAP data confirms that the universe is flat or close to flat. The Gravitational Redshift Gravitational redshift or Einstein shift is the process by which electromagnetic radiation originating from a source that when observed in a lower gravitational potential from a higher gravitational potential relative to the observer its frequency is redshifted. When observed in a higher gravitational potential from a lower gravitational potential relative to the observer, its frequency is blueshifted. The formula below is the gravitational redshift formula or Einstein shift in an uncharged, non rotating, spherical mass.
The Gravitational Redshift Gravitational Redshift describes Doppler between static emitter and receiver in a gravitational field. Static observers in a gravitational field are accelerating, not inertial, in general relativity. As a result (even though they are static) they have a relative velocity in the sense described under Doppler. Because they are static, so is this relative velocity along a light path. In fact, the relative velocity for Doppler turns out to depend only on the difference in gravitational potential between their positions. Typically, we dispense with discussion of the relative velocity along a light path for static observers, and directly describe the resulting red shift as a function of potential difference. When the potential increases from emitter to receiver, you have red shift; when it decreases you have blue shift. The formula below is the gravitational redshift formula or Einstein shift in an uncharged, non rotating, spherical mass.
Mordred said:
[tex]
\frac{\lambda}{\lambda_o}=\frac{1}{\sqrt{(1 - \frac{2GM}{r c^2})}}
[/tex]
G=gravitational constant
c=speed of light
M=mass of gravitational body
r= distance from gravitational body of Mass M
when the signal is 90 degrees to the observer we need to use the Transverse Redshift formula
[tex]
1+z=\frac{1}{\sqrt{1-v^2/c^2}}
[/tex]
What does this have to do with gravitational redshift? It seems to belong under the introductory Doppler section.
Mordred said:
Standard candles
Using standard candles to determine the Hubble constant has a long and honorable history; it's the method used by Hubble himself. The recipe for finnding the Hubble constant is a simple one:
finnding -> finding
Mordred said:
Identify a population of standard candles with luminosity L.
-Measure the redshift z and flux f for each standard candle.
-Compute dL = (L=4¼f)1=2 for each standard candle.
-Plot cz versus dL.
-Measure the slope of the cz versus dL relation when z << 1; this gives
H0.
The CMB, (Cosmic Microwave Background) also provides a good reference point in regards to Homogeneous and Isotropic confirmation, and of distances. However that is best described in greater detail than this article.
For cosmological purposes, a standard candle should be bright enough to be detected at large redshifts. It should also have a luminosity which is well determined. One time-honored variety of standard candle is the class of Cepheid variable stars. Cepheids, as they are known, are highly luminous supergiant stars, As they pulsate radially, their luminosity varies
in response, partially due to the change in their surface area, and partially due to the changes in the surface temperature as the star pulsates. Type 1A supenova is a type of Cepheid.
Without the use of Cepheids measuring distances would be extremely problematic, especially at extremely large distances, These distances are far too large for the parallex method which is a form of triangulation.
Space news on Phys.org
  • #37
I looked over your proposed changes. currently on my phone atm, however I didn't see anything I would object to. In many sections it will give the article a better descriptive. I'll rewrite the article hopefully tomorrow.
  • #38
A few comments:
Strong force is irrelevant...drop that...
but the real point is that the assumptions in GR that lead to an expanding distance [not expanding 'space'] of homogeneity and isotropism do not apply at galactic scales because
of lumps of mass [planets,stars, black holes,etc]
Here are my favorite descriptions on Redshift and Doppler shift collected from various discussions in these forums. If a particular description phrasing catches your fancy and clarifies something, use it; if not, that's ok too. [I may have slightly edited some comments attributed to particular people.]
https://www.physicsforums.com/showthread.php?p=3910924#post3910924
Are Photons Redshifted
Lineweaver and Davis: the universe cools as it expands, much as compressed air in a scuba tank cools when it is released and allowed to expand. The microwave background radiation currently has a temperature of about 2.73 Kelvin, whereas the process that released the radiation occurred at a temperature of about 3,000 Kelvin. Expansion z over the 13.7 Billion years has been about z = 1090: [3,000/1090 = 2.73] appx energy conservation does not hold in expanding geometry
CMB photons were emitted at about 3000 Kelvin and are now 2.73 Kelvin blackbody radiation. They have lost more than 999/1000 of their original energy.
These are two different ways of looking at the same phenomena:
https://www.physicsforums.com/showthr...nt+flow&page=4
[In the great 2007 thread Wallace, Chronos and Oldman take a different view than expressed here [and there] by Marcus...you can read the posts from the 40’s thru 50’s and see the pros and cons. ]
I do think it is better to think of (photons) as being redshifted by being observed in a different frame ...Now as t ticks along, the scale factor a(t) increases. Therefore two observers who are both at rest wrt to the CMB, but who have different times t will therefore be in different frames (have different metrics). This is what leads to photons being redshifted when observed and emitted at different times.
I tend to agree, photons are not redshifted by traveling through the universe, they are redshifted only because they are observed in a different frame from which they were emitted.
Marcus: # 48] I am not comfortable with that because among other things I see cosmologists doing inventories of the energy density which are implicitly estimated IN A CMB FRAME...
These ‘conflicting’ viewpoints stem from this as explained by Chalnoth elsewhere:
” … You get some total redshift for faraway objects due to cosmological expansion. How much of that redshift is due to the Doppler shift# and how much is due to the expansion between us and the far away object is completely arbitrary.”
# Doppler shift is based on [relative velocity] frame based differences, not expansion, Hence photon frequency and wavelength can be viewed as fixed just like in a static Spacetime.. Doppler shift is a particular explanation of redshift, with a particular formula.
You takes your pick
Marcus: A photon emitted from a star at a moderate distance from center of a galaxy will suffer a grav. redshift from the galaxy gravity which is roughly the same size as from the star itself. And that effect (of the star’s gravity) is so tiny that it took sophisticated technique to measure. In the CMB, the grav redshift (so called Sachs-Wolfe effect) is about 10-5 or one thousandth of one percent. It is interesting, but it doesn’t compete in size with the cosmological redshift which for a typical galaxy is several hundred percent. In other words, recession effect overwhelms gravity effect.
Redshift Definition
Doppler Shift
The Doppler effect (or Doppler shift)….is the change in frequency of a wave for an observer moving relative to the source of the wave. .. The frequency of the sounds that the source emits does not actually change….but the received frequency does change… ….. The use of the Doppler effect for light in astronomy depends on ……absorption lines …..where the Doppler effect is recognizable in the fact that the absorption lines are not always at the frequencies that are obtained from the spectrum of a stationary light source. Since blue light has a higher frequency than red light, the spectral lines of an approaching astronomical light source exhibit a blue shift and those of a receding astronomical light source exhibit a redshift…..
Mentz: If A and B use Doppler shift to measure each others clocks then when separating they each see the other’s clock run slowly ( red spectral shift);if they are approaching they each see the other clock running faster ( blue spectral shift)
Jonathan Scott: “In a static situation, gravitational red shift or blue shift is not something that “happens to” photons. It is purely due to relative differences in observer potential, which affects the time rate of the observer’s clocks.
The photon itself has constant frequency relative to a static coordinate system, but an observer at a higher or lower potential will see it to have a different frequency compared with a photon created locally by means of a similar process, for example a particular transition between energy levels.”
Chronos: Redshift is a frame dependent measurement. If you were approaching a distant galaxy at the same speed as it is receeding, you would see no redshift.
PAllen: but gravity or no, at any point along the light path, there are observers who will measure every possible frequency (different states of relative motion between observers). So trying to factor out change due to gravity versus relative motion means identifying which of these frames at different places and times are ‘statically related’, thus differences in frequency are then considered due to gravity.
However, in general, there is no unique or preferred way to make such a global assignment; thus no unambiguous way to separate out gravity from relative motion. In effect, such an assignment amounts to a choice of coordinates. For any such choice, you can say “yes, there is mass/energy producing curvature”, but different choices lead to different divisions of gravitational versus Doppler shift.
Doppler Effect: Frame invariant
PALLEN: The Doppler effect is completely determined by the relative velocity of source and target. Both of these velocities are frame dependent, but the relative velocity between emitter at event of emission and receiver at event of detection is frame invariant. Thus all observers agree on the Doppler measured by a given detector from a given source.
Mathematically, relative speed is defined by parallel transport of 4-velocity from one event to another (Only in SR is this path independent, thus unique), then dot product of transported source 4-velocity with unit 4-vector 4-orthogonal to target 4-velocity. Dot products are invariant - period. (In a standard inertial frame in SR, parallel transport leaves a vector unchanged).
DrGreg:
To show that the Doppler effect is frame invariant you don’t have to do any math at all—just look at the definition ν r /ν s .
ν s is measured by the source using the source’s own proper-time clock.
ν r is measured by the receiver using the receiver’s own proper-time clock.
All observers, whatever coordinates they are using, agree on what the source and receiver’s proper times are (associated with a 2π phase change), therefore agree on the two frequencies, therefore agree on the Doppler factor.
The Doppler effect is mutual between two inertial world lines (each acting as source and target relative to the other). Between an inertial world line and a non-inertial world line it is not mutual….. A light source in forced circular motion around an inertial target is always red shifted. A target in forced circular motion about an inertial light source will see its light always blue shifted.
Cosmological redshift is typically considered distinct from Doppler redshift because it is a relation between distance and redshift rather than speed and redshift, under the assumption that both source and target are motionless relative to center of mass of the local matter (here, local is quite large - galaxy or galaxy cluster).
Marcus:
Don’t think of the redshift as a Doppler [relative velocity] effect. It is not the result of some particular speed. The formula involves the entire [varying] factor by which distances have been expanded during the whole time the light has been traveling.
PeterDonis: The law governing the relationship of emitted to observed photon energies (or frequencies) is general and applies in any spacetime. The 4-momentum of the photon gets determined at the emitter; then it gets parallel transported along the photon’s worldline from emitter to observer; then you contract that 4-momentum with the observer’s 4-velocity to get the observed energy (or frequency if you throw in a factor of Planck’s constant). That “parallel transport” process is actually where the “redshift” occurs in an expanding universe; the expansion alters the 4-momentum of the photon as it travels (or at least that’s one way of looking at it), whereas in a static universe the photon’s 4-momentum would “stay the same” as it traveled.
  • #39
1) Why are all the galaxies accelerating from us ?
10) Why is the CMB, so vital in cosmology ?
Universe: The Universe in cosmology is defined as the Observable Universe The Observable universe from Earth is 46 Billion light years, or 4.3×1026 meters with an age as of 2013, is 13.772 ± 0.059 billion years. So how do we see farther than 13.772 billion years, the answer lies in expansion. As light is traveling towards us, spacetime has expanded.
One common Question posters often ask is " What is outside our Universe, this question has no meaning as without space or time you have nonexistence. Also their is no clear consensus on, if the Universe is Finite or Infinite. " When an object is said to leave our universe" we mean that the object has crossed the observable universe or rather that it is redshifted to the point of non detectable.
The CMB, (Cosmic Microwave Background) The CMB is thermal radiation filling the Observable universe almost uniformaly, This provides strong evidence of the Homogeneous and Isotropic measurements and of distances. As the universe expanded, both the plasma and the radiation filling it grew cooler. When the universe cooled enough, protons and electrons combined to form neutral atoms. These atoms could no longer absorb the thermal radiation, and so the universe became transparent instead of being an opaque fog. Precise measurements of cosmic background radiation are critical to cosmology, since any proposed model of the universe must explain this radiation. The CMBR has a thermal black body spectrum at a temperature of 2.72548±0.00057 Kelvin. CMB photons were emitted at about 3000 Kelvin and are now 2.73 Kelvin blackbody radiation. They have lost more than 999/1000 of their original energy
The Doppler Redshift results from the relative motion of the light emitting object and the observer. If the source of light is moving away from you then the wavelength of the light is stretched out, i.e., the light is shifted towards the red. When the wavelength is compressed from an object moving towards you then it moved towards the blue end of the spectrum. These effects, individually called the blueshift, and the redshift are together known as doppler shifts. The shift in the wavelength is given by a simple formula
[tex]v_r[/tex] is the velocity measured by the source using the source’s own proper-time clock(positive if moving toward the source
[tex]v_s[/tex] is the velocity measured by the reciever using the source’s own proper-time clock(positive if moving away from the reciever)
The above are for velocities where the source is directly away or towards the observer and for low velocities less than relativistic velocities. A relativistic doppler formula is required when velocity is comparable to the speed of light. There are different variations of the above formula for Tansverse Doppler shift or other angles.
Doppler shift is used to describe Redshift due to inertial velocity one example is a car moving away from you the light will be Red Shifted, as it approaches you the light and sound will be blueshifted. In general relativity and cosmology, there is a fundamental complication in this simple picture - relative velocity cannot be defined uniquely over large distances. However, it does become unique when compared along the path of light. With relative velocity compared along the path of the light, the special relativity Doppler formula describes redshift for all situations in general relativity and cosmology. It is important to realize that gravity and expansion of the universe affect light paths, and how emitter velocity information is carried along a light path; thus gravity and expansion contribute to Doppler redshift.
The Cosmological Redshift is a redshift attributed to the expansion of space. The expansion causes a Recession Velocity for galaxies (on average) that is proportional to DISTANCE. This recession velocity then produces a Doppler (red) shift proportional to distance (please note that this recession velocity must be converted to a relative velocity along the light path before it can be used in the Doppler formula). The further away an object is the greater the amount of RedShift. This is given in accordance with Hubbles Law. In order to quantify the velocity of this galactic movement, Hubble proposed Hubble's Law of Cosmic Expansion, aka Hubble's law, an equation that states:
Any measurement of redshift above the Hubble distance defined as H0 = 4300±400 Mpc will have a recessive velocity of greater than the speed of light. This does not violate GR because a recession velocity is not a relative velocity or an inertial velocity. It is precisely analogous to a separation speed. If, in one frame of reference, one object is moving East at .9c, and another West at .9c, they are separating by 1.8c. This is their recession velocity. Their relative velocity remains less than c. In cosmology, two things change from this simple picture: expansion can cause separation speeds much greater even than 2c; and relative velocity is not unique, but no matter what path it is compared along, it is always less than c, as expected.
λ0= rest wavelength
Cosmological Redshift is distance dependant as mentioned above, if you were to teleport to the other side of the galaxy where you measured that greater than light recessive velocity, you would find the same expansion rate as your original location relative to an equal distance. Indeed expansion occurs the same throughout the cosmos. However Gravity in Galaxy clusters are strong enough to prevent expansion. In other words galaxy clusters are gravitationally bound.
Cosmological Constant is a homogeneous energy density that causes the expansion of the universe to accelerate. Originally proposed early in the development of general relativity in order to allow a static universe solution it was subsequently abandoned when the universe was found to be expanding. Now the cosmological constant is invoked to explain the observed acceleration of the expansion of the universe. The cosmological constant is the simplest realization of dark energy, which is the more generic name given to the unknown cause of the acceleration of the universe. Indeed what we term as "Dark" energy is an unknown energy that comprises most of the energy density of our cosmos around 73%. However the amount of dark energy per M3 is quite small some estimates are around about 6 × 10-10 joules per cubic meter. However their is a lot of space between Large scale clusters, so that small amount per M3 adds up to a significant amount of energy in total
Another term often used for the cosmological constant is vacuum energy described originally by the false vacuum inflationary Model by A.Guth. The cosmological constant uses the symbol Λ . the greek letter Lambda.
This False vacuum inflationary model is one that describes a total energy balance of zero, where gravity is the negative energy. In this model what we term as "Nothing " is really a quantum vacuum with quantum fluctuations described by the Heisenburg uncertainty principle. Virtual particles pop in and out of existence all the time, As expansion occurs those virtual particles Quantum tunnel between the false vacuum and the true vacuum, becoming real particles. The full explanation is a little more involved than this quick explanation however this model is often referred to as a "Universe from Nothing" or the "Ultimate free lunch" . Many of our current inflationary models has their roots in this model. However one fundamental problem with all inflationary models is "Runaway expansion" Once the process starts no one has found a mechanism to stop expansion.
One means of relating to expansion is with the use of the a grid of squares. Each horizontal and vertical crossing on that grid is a coordinate. In expansion the space between all coordinates not gravitationally bound expand equally. In other words the coordinates do not change, the space between coordinates change. I should also note their is no clear consensus on whether the universe is finite or infinite. If its infinite now then it was infinite in the past. Same with Finite. The Big Bang model only describes the Universe from 10-43 seconds and is not considered as starting from a black hole singularity, rather its properly described as a rapid expansion of spacetime.
[tex]
[/tex]
c=speed of light
Standard candles
Using standard candles to determine the Hubble constant has a long and honorable history; it's the method used by Hubble himself. The recipe for finding the Hubble constant is a simple one:
-Plot cz versus dL.
H0.
  • #40
I've applied the changes that PAllen supplied, I've also removed the strong Nuclear force statement. Also i used your definition of Vs and Vr. Looking at some of the other statements you supplied Naty1. I wanted to apply one set of changes first then look at modifying to some of the ideas you presented. Also as this is now a cooperative effort, I'd like to hear PAllen's input on some of your ideas.
The improvements are coming along nicely in my humble opinion, with the feedback were now getting this should develop nicely Thanks everyone
  • #41
I can review this tonite, and also think about the information Naty1 collected. Probably won't be till late EST.
  • #42
I like this statement, would be good under the CMB section.
  • #43
One other thing I can see needing improvement is answering question 7. The Standard candle section is inadequate. I could use some suggestions on that section. For full revamp on that portion.
  • #44
This is outside my knowledge base. Hopefully someone else can provide more information.
  • #45
Here is the format I am thinking of replacing the standard candle section.
Cosmic Distance Ladder starting with fundamental distances, then Parallax and some of different types of parallax, including moving cluster parallax stellar parallax.
follow up with standard candles. Then cephieds.
I am currently jotting down ideas for the above items to cover.
Cosmic Distance ladder, also known as extragalactic distance scale. Is easily thought of as a series of different
measurement method's at different distance scales.
Rather than cover a large range of those distance scales or rungs on the ladder I will cover a few of the essential steps to cosmological ditance scales. The fust rung on the ladder is naturally.
Direct measurements: Direct measurements form the fundamental distance scale. Units such as the distance from Earth to the sun that are used to develop a fundamental unit called astronaumical unit or AU.
During the orbit around the sun we can take a variety of measurements such as Doppler shifts to use as a calibration for The AU unit. This Unit is also derived by a method called Parallax.
Parralax. Parralax is essentially trigonometric measurements of a nearby object in space. When our orbit forms a right angle triangle to us and the object to be measured
With the standardized AU unit we can take two AU to form the short leg. The Sun at right angle
to us the distance to the object to be measured.
Still working on this jotting down ideas
  • #46
Mordred said:
Lineweaver and Davis: the universe cools as it expands, much as compressed air in a scuba tank cools when it is released and allowed to expand. The microwave background radiation currently has a temperature of about 2.73 Kelvin, whereas the process that released the radiation occurred at a temperature of about 3,000 Kelvin. Expansion z over the 13.7 Billion years has been about z = 1090: [3,000/1090 = 2.73] appx energy conservation does not hold in expanding geometryCMB photons were emitted at about 3000 Kelvin and are now 2.73 Kelvin blackbody radiation. They have lost more than 999/1000 of their original energy.
In terms of wording this, I would avoid describing photons as losing energy. Just as with light emitted from a neutron star, many (most?) relativists do not consider that photons lost energy escaping; instead they always had less energy from the point of view of distant observers (while having expected energy locally to the emission). It is equally possible to view CMB photons this way, only you say they have less energy as observed 'now' than as observed 'back then' - a difference in spacetime frame not a loss of energy along the way. Just as with gravitational redshift, there are strong proponents on both sides of this. We can sidestep such controversy with wording like:
"CMB photons were emitted at about 3000 Kelvin and are now 2.73 Kelvin blackbody radiation. Their currently observed energy is 1/1000th of their energy as emitted."
As to the Lineweaver I would strengthen "approximate energy conservation does not hold in expanding geometry" to "total energy of the universe cannot be defined for an expanding geometry, so the question of conservation cannot even be posed on the scale of the universe". For the purposes of this FAQ I don't think we need to get into the technicalities that ADM energy is the only reasonable candidate for total energy in GR, and it is undefinable for an RW cosmology. Another argument is that Noether's theorem would not be expected to apply to an expanding geometry, so there is no basis to expect energy conservation.
Otherwise, this is great information to add.
  • #47
That sounds great.
  • #48
Already modified the CMB section in the article. Also moved it up in the article. Location is better suited there.
  • #49
The article is looking really good now. I have only a few comments at this point:
1) You have the phrase: " Many of our current inflationary models has their roots in this model." Change "has" to "have".
2) The formula you give for gravitational redshift is is instead the formula for transverse doppler, which seems out of place here (probably out of place in the whole article). You need to restore the correct formula from earlier versions of this article.
3) As suggested in a post above, change the wording about CMB energy to:
""CMB photons were emitted at about 3000 Kelvin and are now 2.73 Kelvin blackbody radiation. Their currently observed energy is 1/1000th of their energy as emitted."
  • #50
On Naty1's collection of observations, I think the key points of view mentioned are reasonably addressed in the current article. You (Mordred) have already incorporated the temperature decline.
  • #51
Smacks head your right copied the wrong one grrr. Ill restore it after I get some ice for the swelling.
  • #52
The CMB, (Cosmic Microwave Background) The CMB is thermal radiation filling the Observable universe almost uniformaly, This provides strong evidence of the Homogeneous and Isotropic measurements and of distances. As the universe expanded, both the plasma and the radiation filling it grew cooler. When the universe cooled enough, protons and electrons combined to form neutral atoms. These atoms could no longer absorb the thermal radiation, and so the universe became transparent instead of being an opaque fog. Precise measurements of cosmic background radiation are critical to cosmology, since any proposed model of the universe must explain this radiation. . CMB photons were emitted at about 3000 Kelvin and are now 2.73 Kelvin blackbody radiation. CMB photons were emitted at about 3000 Kelvin and are now 2.73 Kelvin blackbody radiation. Their currently observed energy is 1/1000th of their energy as emitted
λ0= rest wavelength
This False vacuum inflationary model is one that describes a total energy balance of zero, where gravity is the negative energy. In this model what we term as "Nothing " is really a quantum vacuum with quantum fluctuations described by the Heisenburg uncertainty principle. Virtual particles pop in and out of existence all the time, As expansion occurs those virtual particles Quantum tunnel between the false vacuum and the true vacuum, becoming real particles. The full explanation is a little more involved than this quick explanation however this model is often referred to as a "Universe from Nothing" or the "Ultimate free lunch" . Many of our current inflationary models have their roots in this model. However one fundamental problem with all inflationary models is "Runaway expansion" Once the process starts no one has found a mechanism to stop expansion.
[tex]
[/tex]
c=speed of light
measurement method's at different distance scales. Rather than cover a large range of those distance scales or rungs on the ladder I will cover a few of the essential steps to cosmological distance scales. The first rung on the ladder is naturally.
Direct measurements: Direct measurements form the fundamental distance scale. Units such as the distance from Earth to the sun that are used to develop a fundamental unit called astronaumical unit or AU. During the orbit around the sun we can take a variety of measurements such as Doppler shifts to use as a calibration for The AU unit. This Unit is also derived by a method called Parallax.
Parallax. Parallax is essentially trigonometric measurements of a nearby object in space. When our orbit forms a right angle triangle to us and the object to be measured
With the standardized AU unit we can take two AU to form the short leg. The Sun at right angle to us the distance to the object to be measured.
Moving Cluster Parallax is a technique where the motions of individual stars in a nearby star cluster can be used to find the distance to the cluster.
Stellar parallax is the effect of parallax on distant stars . It is parallax on an interstellar scale, and allows us to set a standard for the Parsec.
Standard Candles A common misconception of standard candles is that only type 1A supernova are used. Indeed any known fundamental distance measurement, In particular a Stellar objects Luminousity or brightness. By comparing an objects Luminousity to the observed brightness we can calculate the distance to an object using the inverse square law. Standard candles include any object of known Luminousity, such as Cepheids, Novae, Type 1A Supernova. Galaxy clusters,
  • #53
"Parallax", not "parralax".
  • #54
Thanks still working on it but had to check a reference
  • #55
I think that should be a sufficient coverage on Cosmic distance ladder. Article looks good now,
  • #56
maybe the longest FAQ in the history of man!
  • #57
I'd suggest you say we MODEL the universe this way as an approximation. It is this approximation of homogeneity and isotropism that leads to a cosmological constant.
  • #58
This is under 'Doppler Redshift'...
drop 'gravity'...gravity has nothing to do with the redshift of relative motion...
This is a nice section one does not usually see in explanations:
It might be worthwhile mentioning that separation distance is calculated not directly observed...and perhaps provide a 'radar observation' reading...of less than 'c' for your example.
Also, I don't see how cosmology 'changes' separation speeds...maybe just explain that relative velocity along a given path is less than c while recession speeds may not be.
your call...
  • #59
This isn't true. All Freidmann-Lemaitre-Robertson-Walker cosmological models, with or without cosmological constant, are homogeneous and isotropic.
  • #60
This is wrong in GR. Since relative motion is not unique, for Doppler in curved spacetime you must specifically compare (parallel transport) along the light path. Gravity (curvature) affect the light path and how it carries the emitter motion (4 velocity). Doppler in GR is a single combined phenomenon influenced by motion and curvature. Only in special cases (lots of symmetry) can you factor out the motion effect from the curvature effect, but both clearly contribute.
your call...
In flat spacetime, natural coordinates will display a maximum separation speed of 2c. You can construct funky coordinates in flat spacetime to get larger separation speed. However, in cosmological solutions, the natural coordinates reflecting the symmetries of the solution show recession velocities much larger than 2c. I think this point is worth making, but that it is not necessary to belabor it more.
  • #61
Very nice! I hope a few more people proof read it for polishing, but it looks good enough to me.
  • #62
λ0= rest wavelength
[tex]
[/tex]
c=speed of light
Standard Candles A common misconception of standard candles is that only type 1A supernova are used. Indeed any known fundamental distance measurement, In particular a Stellar objects Luminousity or brightness. By comparing an objects Luminousity to the observed brightness we can calculate the distance to an object using the inverse square law. Standard candles include any object of known Luminousity, such as Cepheids, Novae, Type 1A Supernova. Galaxy clusters.
My thanks to the following Contributors for their feedback and support.
PAllen
Naty1
Jonathon Scott
marcus
Article by Mordred, PAllen
  • #63
Just added the contributors list to the article.
  • #64
I heard a request for an Office Assistant. Your request has been answered... :biggrin: I have read the entire text and I will provide my suggestions below (mostly formal and very little science), from top to bottom:
Redshift -> redshift
Dopplershift -> Doppler shift
Why is the CMB, so vital in cosmology ? (remove comma)
There are many words that currently are capitalized, but should not be capitalized, unless they are at the start of a sentence.
These are:
Expansion, Homogeneous, Isotropic, Billion, Question, Finite, Infinite, Observable, Redshift, Recession Velocity, Gravity, Galaxy clusters, False vacuum, "Nothing", Quantum tunnel, "Universe from Nothing", "Ultimate free lunch", "Runaway expansion", Parallax, Moving Cluster Parallax
Further suggestions:
The Observable universe from Earth is 46 Billion light years (ambiguous, use e.g. "The radius of the observable universe is...")
"So how do we see farther than 13.772 billion years, the answer lies in expansion. As light is traveling towards us, spacetime has expanded."
This is a question without a question mark, split to e.g.
"So how do we see farther than 13.772 billion years? The answer lies in expansion; as light is traveling towards us, spacetime has expanded."
"What is outside our Universe, this question has no meaning as without space or time you have nonexistence."
A question without question mark, split to e.g.
"What is outside our Universe? This question..."
concensus -> consensus
non detectable->nondetectable
uniformaly->uniformly
"CMB photons were emitted at about 3000 Kelvin and are now 2.73 Kelvin blackbody radiation."
This is repeated twice. CMB is important, but not that important :biggrin:.
"In all cases of Doppler" - insert "shift", I think.
"Red/Blue shifted"-> "red- or blueshifted"
"red/blue end of the spectrum. As shown by the formula below."
-> "red or blue end of the spectrum, as shown by the formula below."
"reciever"->"receiver" (twice)
"relativistic doppler formula"->"relativistic Doppler formula"
"Tansverse Doppler shift"->"transverse Doppler shift"
Insert punctuation: "Doppler shift is used to describe redshift due to inertial velocity. One example..."
"Red Shifted"->"redshifted"
"RedShift"->"redshift"
"Hubbles Law"->"Hubble's Law" (twice)
"GR"->"general relativity" (it's a newbie FAQ, remember :smile:)
"East"->"east", "West"->"west"
"Milky way"->"Milky Way"
"distance dependant"-> e.g. "depending on distance"
"Cosmological Constant"->"The cosmological constant"
"dark energy per M3"->"dark energy per m3"
"small amount per M3"->"small amount per m3"
"Heisenburg uncertainty principle"->"Heisenberg uncertainty principle"
"One means of relating to expansion is with the use of the a grid of squares."
I suggest perhaps
"One way to describe expansion is to use a square grid."
"their is no clear concensus"->"there is no consensus"
"blackhole singularity"->"black hole singularity"
"describes Doppler between static emitter"
->"describes Doppler shift between a static emitter"
"red shift"->"redshift" (multiple)
"blue shift"->"blueshift"
"non rotating"->"nonrotating"
"Cosmic Distance ladder"->"Cosmic distance ladder"
"method's"->"methods"
"the sun"->"The Sun" (twice)
"for The AU unit. This Unit"->"for the AU unit. This unit"
"The Sun at right angle"->"The Sun at a right angle"
"the Parsec"->"the parsec"
"Standard Candles"->"Standard candles"
"In particular a Stellar objects Luminousity or brightness"
"In particular a stellar object's luminosity or brightness"
Luminousity -> luminosity (multiple)
"Novae"->"novae", "Supernova"->"supernova", "Galaxy clusters"->"galaxy clusters".
From your friendly office assistant, over and out. :smile:
  • #65
Come on, surely you can do better than this garbled mess! For a start "their is" should be "there is" and "consensus" only has one c (like "consent"), and the double quotes seem to be randomly scattered.
I appreciate your attempts, but I don't think this is anywhere near up to the appropriate quality for an FAQ item so far.
  • #66
I never claimed the article is complete. Right now were in the proofing stage. That includes better ways to express the ideas presented in the article. In an article this size its easy to miss mistakes, hence multiple eyes
  • #67
These are:
I suggest perhaps
Many thanks I'll make those corrections.
  • #68
This is wrong in GR. ... for Doppler in curved spacetime you must specifically compare (parallel transport) along the light path. Gravity (curvature) affect the light path and how it carries the emitter motion (4 velocity). ...
oops..I did not read the original context carefully...it's clearly and properly stated as a path effect.
  • #69
For an FAQ you need to be really straightforward and uncontroversial. It's difficult. I hope others have time to help you sort it out.
Have you tried calculating the redshift (to first order) within a rapidly spinning system such as a space station (a) as a Special Relativity velocity effect and (b) as due to the effective "gravitational potential" experienced within the spinning system because of the centripetal acceleration? I've always felt that's particularly educational.
  • #70
1) Why are all the galaxies accelerating from us?
2) Is Redshift the same as Doppler shift?
3) What is causing the expansion of the universe?
4) Is expansion, faster than light in parts of the Universe, and How does this not violate the faster than light speed limit?
5) What is a Cepheid or standard candle?
6) What do we mean when we say homogeneous and isotropic?
7) How do we measure the distance to galaxies?
8) What is outside the universe?
9) What do we mean when anm object leaves our universe?
10) Why is the CMB so vital in cosmology?
The parsec (symbol: pc) is a unit of length used in astronomy, equal to about 30.9 trillion kilometers (19.2 trillion miles). In astronomical terms, it is equal to 3.26 light-years, and in scientific terms it is equal to 3.09×1013 kilometers
Universe: A generalized definition of the universe can be described as everything that is. In Cosmology the universe can be described as everything measurable in our space-time either directly or indrectly. Or the Observable universe. The observable universe is 46 Billion light years, or 4.3×1026 meters with an age as of 2013, is 13.772 ± 0.059 billion years.
In the hot big bang model we do not think of the universe as starting from a singularity (infinitely, hot, dense point) instead measurements agree space-time simply expanding.
Whether or not the universe is finite or infinite is not known. However if it is infinite now so it must be in the beginning.
Common misconceptions arise when one tries to visualize a finite universe Such questions include.
"So how do we see farther than 13.772 billion years?" The answer lies in expansion; as light is traveling towards us, space-time has expanded.
" If the universe is finite what exists outside the Universe?" If you think about this question with the above definition of the universe you will realize that the question is meaningless. One accurate answer in regards to cosmology is nonexistent.
"What makes up the barrier between our universe and outside our universe?" The short answer is there is no barrier.
The CMB, (Cosmic Microwave Background) The CMB is thermal radiation filling the Observable universe almost uniformly, This provides strong evidence of the homogeneous and isotropic measurements and distances. As the universe expanded, both the plasma and the radiation filling it grew cooler. When the universe cooled enough, protons and electrons combined to form neutral atoms. These atoms could no longer absorb the thermal radiation, and so the universe became transparent instead of being an opaque fog. Precise measurements of cosmic background radiation are critical to cosmology, since any proposed model of the universe must explain this radiation. CMB photons were emitted at about 3000 Kelvin and are now 2.73 Kelvin blackbody radiation. Their currently observed energy is 1/1000th of their energy as emitted
Doppler shift and redshift are the same phenomenon in general relativity. However you will often see Doppler factored into components with different names used, as will be explained below. In all cases of Doppler, the light emitted by one body and received by the other will be red or blueshifted i.e. its wavelength will be stretched. So the color of the light is more towards the red or blue end of the spectrum. As shown by the formula below.
The Doppler Redshift results from the relative motion of the light emitting object and the observer. If the source of light is moving away from you then the wavelength of the light is stretched out, i.e., the light is shifted towards the red. When the wavelength is compressed from an object moving towards you then it moves towards the blue end of the spectrum. These effects, individually called the blueshift and the redshift are together known as Doppler shifts. The shift in the wavelength is given by a simple formula
c=velocity of waves in a medium
[tex]v_s[/tex] is the velocity measured by the receiver using the source’s own proper-time clock(positive if moving away from the receiver)
The above are for velocities where the source is directly away or towards the observer and for low velocities less than relativistic velocities. A relativistic Doppler formula is required when velocity is comparable to the speed of light. There are different variations of the above formula for transverse Doppler shift or other angles.
Doppler shift is used to describe redshift due to inertial velocity one example is a car moving away from you the light will be redshifted, as it approaches you the light and sound will be blueshifted. In general relativity and cosmology, there is a fundamental complication in this simple picture - relative velocity cannot be defined uniquely over large distances. However, it does become unique when compared along the path of light. With relative velocity compared along the path of the light, the special relativity Doppler formula describes redshift for all situations in general relativity and cosmology. It is important to realize that gravity and expansion of the universe affect light paths, and how emitter velocity information is carried along a light path; thus gravity and expansion contribute to Doppler redshift.
The Cosmological Redshift is a redshift attributed to the expansion of space. The expansion causes a Recession Velocity for galaxies (on average) that is proportional to DISTANCE. This recession velocity then produces a Doppler (red) shift proportional to distance (please note that this recession velocity must be converted to a relative velocity along the light path before it can be used in the Doppler formula). The further away an object is the greater the amount of redshift. This is given in accordance with Hubble’s Law. In order to quantify the velocity of this galactic movement, Hubble proposed Hubble's Law of Cosmic Expansion, aka Hubble's law, an equation that states:
Hubble’s Law: The greater the distance of measurement the greater the recessive velocity
Velocity = H0 × distance.
The Hubble Constant has been calculated at different values over time, this is essential as the rate of expansion varies over time but the current accepted value is 70 kilometers/second per mega parsec, or Mpc. The latter being a unit of distance in intergalactic space described above.
Any measurement of redshift above the Hubble distance defined as H0 = 4300±400 Mpc will have a recessive velocity of greater than the speed of light. This does not violate GR because a recession velocity is not a relative velocity or an inertial velocity. It is precisely analogous to a separation speed. If, in one frame of reference, one object is moving east at .9c, and another west at .9c, they are separating by 1.8c. This is their recession velocity. Their relative velocity remains less than c. In cosmology, two things change from this simple picture: expansion can cause separation speeds much greater even than 2c; and relative velocity is not unique, but no matter what path it is compared along, it is always less than c, as expected.
λ0= rest wavelength
a redshift. However, the vast majority of galaxies have z > 0. One notable blueshift example is the Andromeda Galaxy, which is gravitationally bound and approaching the Milky Way.
Cosmological Redshift is distance dependant as mentioned above, if you were to teleport to the other side of the galaxy where you measured that greater than light recessive velocity, you would find the same expansion rate as your original location relative to an equal distance. Indeed expansion is the same throughout the cosmos. However gravity in galaxy clusters is strong enough to prevent expansion. In other words galaxy clusters are gravitationally bound.
In regards to expansion it is important to realize that galaxies are not moving from us due to inertia, rather the space between two coordinates are expanding. This is important in that no FORCE is acting upon the galaxies to cause expansion. That expansion is homogeneous and isotropic. In other words, there is no preferred location ( Homogeneous) and no preferred direction (Isotropic). Keep in mind these terms describe the universe on large scales. Indeed below 100 Mpc we know that galaxy clusters, large scale clusters are not homogeneous or isotropic.
Cosmological Constant is a homogeneous energy density that causes the expansion of the universe to accelerate. Originally proposed early in the development of general relativity in order to allow a static universe solution it was subsequently abandoned when the universe was found to be expanding. Now the cosmological constant is invoked to explain the observed acceleration of the expansion of the universe. The cosmological constant is the simplest realization of dark energy, which the more generic name is given to the unknown cause of the acceleration of the universe. Indeed what we term as "Dark" energy is an unknown energy that comprises most of the energy density of our cosmos around 73%. However the amount of dark energy per m3 is quite small. Some estimates are around about 6 × 10-10 joules per cubic meter. However their is a lot of space between large scale clusters, so that small amount per m3 adds up to a significant amount of energy in total
Another term often used for the cosmological constant is vacuum energy described originally by the false vacuum inflationary Model by A.Guth. The cosmological constant uses the symbol Λ, the Greek letter Lambda.
This False vacuum inflationary model is one that describes a total energy balance of zero, where gravity is the negative energy. In this model what we term as "Nothing” is really a quantum vacuum with quantum fluctuations described by the Heisenberg uncertainty principle. Virtual particles pop in and out of existence all the time, as a result of expansion those virtual particles quantum tunnel between the false vacuum and the true vacuum, becoming real particles. The full explanation is a little more involved than this quick explanation however this model is often referred to as a "Universe from Nothing" or the "Ultimate free lunch" . Many of our current inflationary models have their roots in this model. However one fundamental problem with all inflationary models is "Runaway expansion" Once the process starts no one has found a mechanism to stop expansion.
One means of relating to expansion is with the use of a grid of squares. Each horizontal and vertical crossing on that grid is a coordinate. In expansion the space between all coordinates not gravitationally bound expand equally. In other words the coordinates do not change, the space between coordinates change. I should also note there is no clear consensus on whether the universe is finite or infinite. If it’s infinite now then it was infinite in the past. Same thing applies with finite. The Big Bang model only describes the Universe from 10 -43 seconds and is not considered as starting from a black hole singularity, rather its properly described as a rapid expansion of space-time.
Gravitational Redshift describes Doppler between static emitter and receiver in a gravitational field. Static observers in a gravitational field are accelerating, not inertial, in general relativity. As a result (even though they are static) they have a relative velocity in the sense described under Doppler. Because they are static, so is this relative velocity along a light path. In fact, the relative velocity for Doppler turns out to depend only on the difference in gravitational potential between their positions. Typically, we dispense with discussion of the relative velocity along a light path for static observers, and directly describe the resulting redshift as a function of potential difference. When the potential increases from emitter to receiver, you have redshift; when it decreases you have blue shift. The formula below is the gravitational redshift formula or Einstein shift in an uncharged, non rotating, spherical mass.
[tex]
[/tex]
c=speed of light
Cosmic Distance ladder, also known as Extragalactic distance scale. Is easily thought of as a series of different measurement methods for specific distance scales. Rather than cover a large range of those distance scales or rungs on the ladder I will cover a few of the essential steps to cosmological distance scales. The first rung on the ladder is naturally.
Direct measurements: Direct measurements form the fundamental distance scale. Units such as the distance from Earth to the sun that are used to develop a fundamental unit called astronomical unit or AU. During the orbit around the sun we can take a variety of measurements such as Doppler shifts to use as a calibration for the AU unit. This Unit is also derived by a method called Parallax.
With the standardized AU unit we can take two AU to form the short leg. With the Sun at a right angle to us the distance to the object to be measured is the long leg of the triangle.
Stellar parallax is the effect of parallax on distant stars . It is parallax on an interstellar scale, and allows us to set a standard for the parsec.
Standard candles A common misconception of standard candles is that only type 1A supernova are used. Indeed any known fundamental distance measurement or stellar object whose luminosity or brightness is known can be used as a standard candle. By comparing an objects luminosity to the observed brightness we can calculate the distance to an object using the inverse square law. Standard candles include any object of known luminosity, such as Cepheid’s, novae, Type 1A supernova and galaxy clusters.
My thanks to the following Contributors, for their feedback and support.
PAllen
Naty1
Jonathon Scott
marcus
