MHB Reduce the following Boolean equation.
  • Thread starter Thread starter shamieh
The Boolean equation f(w,x,y,z) = (x + z)(x + \bar{z})(x + \bar{y}) can be simplified to f(w,x,y,z) = x, demonstrating that the original expression can be reduced. The simplification process involves applying the distributive laws of Boolean algebra, specifically how disjunction distributes over conjunction. There was confusion regarding the application of these laws, particularly in how terms are combined and simplified. The discussion clarified that z and \bar{z} multiply to zero, which is a key step in the reduction process. Overall, the participants worked through the simplification, enhancing their understanding of Boolean algebra principles.
shamieh
Is this correct?
The following Boolean equation can be reduced any farther than it already is? Write out the simplified formula.
$$$f$(w,x,y,z) = (x + z) * (x + \bar{z}) * (x + \bar{y})$$
My answer: $$(x)(\bar{y})$$ ?
Technology news on Phys.org
No, the first expression is true when x = y = z = 1, but the second expression is false.
We have\[\begin{align*}(x + z)(x + \bar{z})(x + \bar{y}) &= (x+z\bar{z})(x+\bar{y})&& \text{by distributivity of disjunction over conjunction}\\ &=x(x+\bar{y})&& \text{since }z\bar{z}=0\\ &=x+x\bar{y}&& \text{by distributivity of conjunction over disjunction}\\ &=x(1+\bar{y})&&\text{since } x=x\cdot1\\ &=x\cdot1&&\text{since }1+\bar{y}=1\\ &=x\end{align*}\]
When you say
$$(x + z)(x + \bar{z})(x + \bar{y}) = (x + z\bar{z})(x + \bar{y}) $$
<-- How are you getting this result? I am confused.
Are you saying: $$(xx + x\bar{z} + xz + z\bar{z})$$ <-- This is just FOILing the first two. What about the one in the last parenthesis? Can you please show details because I am very confused.
Or are you saying
$$xx + xz! + xx + xy! + xz + zz! + xz + zy!$$ ?
$(x+z)(x+\bar{z})=(x+z\bar{z})$ is distributivity of disjunction over conjunction, which I described in a https://driven2services.com/staging/mh/index.php?posts/30680/.
oh wait I see.
(x + z)(x + z!)(x + y!)
so:
(xx + zz!)(x + y!) = x(x + y!) = then Factor x(1 + y!) and 1 +y! = 1 thus x*1=x. Wow I had to stare at it for a couple minutes. Thanks for the Help, sorry for the hassle lol.
so:
(xx + zz!)(x + y!)
You are writing (x + z)(x + z!) = (xx + zz!) as if you multiplied the first terms (i.e., x and x) and then the second terms (i.e., z and z!) in the two sets of parentheses. There is no law that allows you to do this. Please take a minute to read my description of distributivity of disjunction over conjunction in the other thread and be sure you understand why it is called distributivity and how the two types of distributivity in Boolean algebra are similar.
You aren't multiplying x and x together but you ARE multiplying z and $$\bar{z}$$ to get $$z\bar{z} = 0 $$ correct? If that is was you are doing then I made a mistake and understand how to do it now, if something else is going on then I will need to re-read the definition.
- - - Updated - - -
like for example if i had $$(a + b)(a + \bar{b})(a + c) $$
i would get by, disjunc over conjunc.
$$(a + b\bar{b})(a + c) = a(a + c) = a(1 + c) = a (1+c = 1) = a(1) = a$$
Yes.
In general, distributivity of some operator % over some other operator # says the following:
x % (y # z) = (x % y) # (x % z).
If % is disjunction (+) and # is multiplication (*), then this amounts to
x + (y * z) = (x + y) * (x + z),
or
x + yz = (x + y)(x + z).
In the right-hand side, one term in both sets of parentheses is the same: x. The other two terms (y and z) are multiplied and the result is added to x to produce the left-hand side.
Great Explanation! Thanks!
