Leannie
- 7
A turbine generator is delivering a 20MW load at 50Hz, to a local load.; it is not connected to the grid. The load suddenly drops to 15 MW, and the governor starts to open the steam valve after 0.5s. Calculate the frequency to which the generated voltage rises, before the steam flow decreases in response to the reduced load. The stored energy in the rotating parts is 80MJ at 3000rpm.
I know it a 2 pole generator from p=120f/n (don't know if this matters)
I also know reducing the torque will give a reduced power output.
power(kW)=(2∏×torque(Nm)×rpm)/60000
torque=(60000×power)/(2∏×rpm)
P=E/t
During the 0.5 seconds before the steam flow is reduced there is extra power generated.
20MW-15MW=5MW
E=Pt=5MWx0.5s
E=2.5MJ
Total energy from rotating parts=80MJ+2.5MJ=82.5MJ
(2.5/80)x100=3.125% increase in energy at shaft
Will the frequency simply then be an increase of 3.125% i.e. 50+(50x0.03125)=51.5625Hz
Or is it more complicated than this, would the torque be considered?
Thanks
