Refraction of Light: Is There No Refraction?
When light transitions between air and water, refraction typically occurs, altering its direction. If the light is traveling parallel to the normal, the angle of refraction is indeed 0 degrees, meaning there is no change in direction. This situation leads to the conclusion that the sine of the angle is zero, confirming no refraction takes place. The discussion highlights the specific conditions under which refraction is absent. Understanding these principles is essential for comprehending light behavior at different interfaces.
AkshayPitt
I understand that when light goes between air and water, refraction occurs (either towards or away from the normal). If the light going between air and water is already going in the same direction as the normal, is there no refraction (or a refraction angle of 0 degrees)?
Thank you.
Science news on Phys.org
What is the sin of zero?
sin(0) = 0
Thanks a lot for your help!
Thread 'Simple math model for a Particle Image Velocimetry system'
Hello togehter, I am new to this forum and hope this post followed all the guidelines here (I tried to summarized my issue as clean as possible, two pictures are attached). I would appreciate every help: I am doing research on a Particle Image Velocimetry (PIV) system. For this I want to set a simple math model for the system. I hope you can help me out. Regarding this I have 2 main Questions. 1. I am trying to find a math model which is describing what is happening in a simple Particle...
Thread 'How to model converging illumination through object plane (in ZEMAX)'
Hello community, I'm designing a projection lens system for a 35mm film projector in Zemax OpticStudio and struggling with the correct sequential mode setup for the illumination geometry. The light source is a Xenon short-arc lamp reflected by an ellipsoid mirror, which creates a converging cone with a 40.6 degree full angle that passes through the film gate. The film gate is my object plane, but the light doesn't diverge from it like a typical Lambertian source. Instead, the converging...
