- #71
PeterDonis
Mentor
- 46,776
- 23,282
ModusPwnd said:I define "observation" as something that affects the wavefunction such that an interference pattern is not produced.
Ok, but you need to understand that not everybody uses this definition. Again, "observation" is an ordinary language term. Your definition links this term to actual stuff in the physical model, which is good if you want to discuss physics. But not everybody wants to use the term "observation" for that purpose.
ModusPwnd said:Again, that looks like a clear statement that consciousness is not required to be an observation or collapse the wavefunction or whatever you want to call destroying the interference pattern.
Now you're throwing together two different things. You defined "be an observation" as "something that affects the wavefunction such that an interference pattern is not produced". This refers, as I said above, the actual stuff in the physical model--stuff that affects the wavefunction.
However, "collapse the wavefunction" does not refer to anything in the physical model. It's an interpretation. You can describe the same physical model--the same math--without ever using the term "collapse" at all (e.g., using the MWI). So by your definition of "observation", "collapse the wavefunction" is not even the same kind of thing as an observation.
So you have taken what looks to you like a "clear statement" and made it into a muddle of two different things. The first amounts to saying that consciousness does not appear anywhere in the physical model--the math of QM doesn't invoke consciousness anywhere to explain what happens to the wavefunction. That's true (and is basically what I've been saying).
But the second thing is a statement about an interpretation--a version of the collapse interpretation in which "collapse" only happens when a conscious observer looks at something. This has nothing to do with the actual physical model, because "collapse" doesn't appear anywhere in that model, any more than consciousness does. I haven't said anything at all about whether that interpretation is "right" or not; I personally don't even think that's a meaningful question.
