Regarding current sensitivity of galvanometer
In summary, a galvanometer is an instrument that detects and measures small electrical currents by using a coil of wire suspended in a magnetic field. It works by creating a magnetic field that interacts with a permanent magnet, causing the coil to rotate and move a pointer along a scale. The sensitivity of a galvanometer refers to its ability to detect small changes in current and is determined by its design, including the strength of the magnetic field, number of turns in the coil, and type of suspension used. To increase sensitivity, one can adjust these factors or use a higher quality instrument with less friction and better calibration.
logearav
338
a galvanometer with 50 divisions on the scale requires a current sensitivity of 0.1 m A/division. find the galvanometer current?
IS= [tex]\theta/I[/tex]
TO find the galvanometer current, i multiplied 50 with 0.1 to get the galvanometer current, as instructed by my physics teacher. my query is how this multiplication gives galvanometer current. is there any formula/
This literally is just the current that causes the meter to read maximum... nothing sinister.
Related to Regarding current sensitivity of galvanometer
1. What is a galvanometer?
A galvanometer is an instrument used to detect and measure small electrical currents. It works by using a coil of wire suspended in a magnetic field, which experiences a torque when a current passes through it.
2. How does a galvanometer work?
A galvanometer consists of a coil of wire, a magnet, and a pointer. When a current passes through the coil, it creates a magnetic field that interacts with the magnetic field of the permanent magnet. This interaction causes the coil to rotate, which moves the pointer along a scale to indicate the strength and direction of the current.
3. What is the sensitivity of a galvanometer?
The sensitivity of a galvanometer refers to its ability to detect and measure small changes in current. It is typically measured in microamperes per division, with higher sensitivity indicating the ability to detect smaller changes in current.
4. How is the current sensitivity of a galvanometer determined?
The current sensitivity of a galvanometer is determined by its design, specifically the strength of the magnetic field, the number of turns in the coil, and the type of suspension used for the coil. These factors affect the amount of torque the coil experiences and, therefore, its ability to detect small changes in current.
5. How can the sensitivity of a galvanometer be increased?
The sensitivity of a galvanometer can be increased by increasing the strength of the magnetic field, increasing the number of turns in the coil, or using a more sensitive suspension for the coil. Additionally, using a higher quality instrument with less friction and better calibration can also improve sensitivity.
