High School Regarding electron-positron annihilation
  • Thread starter Thread starter Rev. Cheeseman
    annihilation
When an electron collides with a positron, they annihilate each other, producing photons that propagate outward at the speed of light. The fate of these photons depends on their interactions with other matter; they may be absorbed or continue traveling through space. High-energy photons can even create new electron-positron pairs upon interaction. This process is akin to the behavior of photons emitted from everyday light sources. Ultimately, the photons generated in electron-positron annihilation either disperse into space or interact with other particles.
Rev. Cheeseman
When an electron meets an anti-electron which is also known as positron and collide, the particles will become photons. But where did the photons go after the electron-positron annihilation happened?
Outward.
Vanadium 50 said:
Outward.
I mean do they ended up absorbed by something or simply gone?
They simply propagate out away from the point of annihilation at the speed of light. Whether they get absorbed depends on what they encounter along the way. It's similar to what happens to the photons that leave your flashlight.
If the photons have high enough energy, they can in turn produce new electron-positron pairs. This bubble-chamber picture shows a positron (orange) entering from the lower left and annihilating with an electron in the bubble-chamber fluid. One of the photons (purple-dot path) produces an electron-positron pair (green) at upper right. The other photon (invisible) leaves the field of view.
(Source at CERN)
Depends on what they hit. Just like photons from a light bulb or a star.
I do not have a good working knowledge of physics yet. I tried to piece this together but after researching this, I couldn’t figure out the correct laws of physics to combine to develop a formula to answer this question. Ex. 1 - A moving object impacts a static object at a constant velocity. Ex. 2 - A moving object impacts a static object at the same velocity but is accelerating at the moment of impact. Assuming the mass of the objects is the same and the velocity at the moment of impact...
13K
  • · Replies 23 ·
