Regualr hexagon and position vector - how does this work
rohan03
a regular hexagon OPQRST has its vertices at O ( the origin) and points P,Q,R, S,T with position vector p,q,r,s,t respectively. The point U with position vector u is the midpoint of the line segment OP, and SU meets OR at the point V
please see attached diagem
I need to show that the position vector r=2(p+t) and write down the position vector u and s, in terms of p and t.
Now what I do know is I have marked on my diagram in colour - however I am not sure any further as this is very new to me. so your help will be appreciated.
At the moment you have had 73 viewers and 2 of them looked at your word document. Many of us, myself included, will not open a Word document off the internet. You will have more luck if you post a simple graphic so we can see it when we read your post.
Ok. Will do.
here I am attaching bitmap so jope someone can help.. word doc is problem so I will remove it
Here's a start: ##r = p + PQ +QR##. Can you show from the geometry of the regular hexagon that ##QR = t## and ##PQ = p + t##? That should get you your equation for ##r##.
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
