Related Rates and acceleration
The discussion revolves around solving a related rates problem involving the relationship between distance (s) and velocity (v) given by v = 150s/(3+s). The user has derived an expression for acceleration (a) but is unsure how to eliminate v from their final answer. Participants point out a mistake in the user's calculations and suggest using the original velocity equation to substitute v back into the acceleration formula. Ultimately, the user acknowledges the clarification and understands that substituting v with the expression in terms of s will yield the desired result.
Mspike6
I have a question about a related rates, i already solved it, but i would like someone to confirm it to me .
* The relation between distance s and velocity v is given by v=\frac{150s}{3+s}. Find the acceleration in terms of s.
Solution:
\frac{d}{dt} (V) = \frac{d}{dt}[\frac{150s}{3+s}]\frac{dv}{dt} = 150 \frac{d}{dt} \frac{s}{3+s}\frac{dv}{dt} =150 [ \frac{(3+s)(s') - (s)(s')}{(3+s)^2]}\frac{dv}{dt} = \frac{150s'}{(3+s)^2}a= \frac{450v}{(3+s)^2}
As you can see my final answer is a in terms of v and s, not s only .. .but am not sure what to do to getrid of this v..
Thanks
There's a mistake between the third and forth lines. Also, what substitution can you make to get rid of v?
thanks, the 4th line should be \frac{dv}{dt}= \frac{450v}{(3+s)^2}
am not sure what sub. get rid of v.
but v' will give me a instead of v, but is that possible, i mean, if i want to get V' i will have to take thderivative for the whole thing.
Your original velocity equation expresses v in terms of s; use that.
sorry but i don't know what you mean .
The Question asked me to find a in terms of s , not v in terms of s
your expression for a is correct, but it contains a 'v'. in order to express a completely in terms of s, you need to use the equation v=\frac{150s}{3+s} and plug this into your equation for a.
Ah, that make sense, thank you :D
  • · Replies 24 ·
