Related Rates Coffee Filter Problem
manik
Coffee drains from a conical filter, with diameter of 15cm and a height of 15 cm into a cylindrical coffee pot, with a diameter of 15 cm at 2 cm^2/ sec. At a certain time, the coffee in the filter is 13 cm deep.
a) How fast is the depth of coffee in the filter changing at that time?
b) How fast is the depth of coffee in the pot changing at that time?
Apparently this is an assignment question. I think that 2cm^2 / sec is a typo and should be replaced by 2cm^3 / sec.
http://img242.imageshack.us/img242/3917/attemptau7.jpg
<< that is my attempt for problem a), is this right? Can someone make any suggestions.. thanks in advance
I'm getting 8/(169 * Pi) cm/s as my answer. I think one place where you did something wrong was you did not square h/2 in place of r in the original volume equation. It should have looked something like this.
v = 1/3 * PI * r^2 * h --> r = h/2 --> v = 1/3*Pi*(h/2)^2*h which gives
v = 1/12*Pi*h^3 By differentiation we obtain:
dv = 1/4*Pi*h^2*dh solving for dh we get (4*dv)/(Pi*h^2) or 8/(169*Pi) cm/s.
thanks i got a, but can someone tell me for b i don't get it
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
