I Relating orthogonal accelerations in special relativity
LightPhoton
TL;DR Summary
Reasoning for the validity of relation between orthogonal accelerations in special relativity
We want to relate acceleration in two frames, an inertial frame S, and the instantaneous inertial reference frame of the particle on which it is being accelerated, S', which is moving in the ##x## direction at the moment. Let the acceleration in S be ##(a_x,a_y)## and in S' be ##(a_x',a_y')##. We want a relationship between them.
Now, here Morin argues that when consider the ##y## component we can write ##dy=dy'## and that ##dt'=dt/\gamma##, thus
$$a_y'=d^2y'/dt'^2=d^2y/(dt/\gamma)^2=\gamma^2a_y\tag1$$
But this seems wrong since we are taking the derivative of a factor of ##\gamma## here. If we go into a bit more detail then,
$$a_y=\frac{d^2y}{dt^2}=\frac d{dt}\bigg(\frac{dy'}{\gamma dt'}\bigg)=\frac1{\gamma^2}a_y'+\underbrace{\frac{dy'}{dt'}}_{v'}\frac d{dt}\bigg(\frac1{\gamma}\bigg)$$
but since the particle is at rest with respect to itself ##(v'=0)##, the second term goes to zero and we get ##(1)##. Is this reasoning correct?
I think you are applying the chain rule here, and I agree that's the formally correct approach. However note that the structure of the Lorentz transforms, which are aligned parallel to the x axis, tells you that the velocity of the particle is parallel to x (otherwise you couldn't use these transforms to reach its rest frame). Hence ##dy/dt=0## in any frame, not just the rest frame.
I think that's why Morin is taking a shortcut here.
Likes LightPhoton
I asked a question here, probably over 15 years ago on entanglement and I appreciated the thoughtful answers I received back then. The intervening years haven't made me any more knowledgeable in physics, so forgive my naïveté ! If a have a piece of paper in an area of high gravity, lets say near a black hole, and I draw a triangle on this paper and 'measure' the angles of the triangle, will they add to 180 degrees? How about if I'm looking at this paper outside of the (reasonable)...
From $$0 = \delta(g^{\alpha\mu}g_{\mu\nu}) = g^{\alpha\mu} \delta g_{\mu\nu} + g_{\mu\nu} \delta g^{\alpha\mu}$$ we have $$g^{\alpha\mu} \delta g_{\mu\nu} = -g_{\mu\nu} \delta g^{\alpha\mu} \,\, . $$ Multiply both sides by ##g_{\alpha\beta}## to get $$\delta g_{\beta\nu} = -g_{\alpha\beta} g_{\mu\nu} \delta g^{\alpha\mu} \qquad(*)$$ (This is Dirac's eq. (26.9) in "GTR".) On the other hand, the variation ##\delta g^{\alpha\mu} = \bar{g}^{\alpha\mu} - g^{\alpha\mu}## should be a tensor...
