Relationship between closing a switch and the total battery current
Closing a switch creates an additional pathway for current to flow, which increases the total current in the circuit without altering the original path's current. The current through the capacitor (C) becomes an additional component when the switch is closed. Understanding the principles of series and parallel circuits is essential for grasping these concepts. The discussion emphasizes the importance of foundational knowledge in electrical circuits. Overall, the relationship between closing a switch and total battery current hinges on the configuration of the circuit.
kbrockway2021
This problem solution says that by closing the switch, battery current will increase. However, the voltage is the same, and the resistance is only increasing by adding another light bulb. So how is the current increasing
V=IR
Hello @kbrockway2021 ,
:welcome: ##\qquad## !​
See it this way: you add another path through which current can flow -- without changing anything in the original path, so here the current stays the same. When the swich is closed, the current through C will be additional.
You need to study the basics of serial and parallel
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
