redtree
- 313
- 13
Given the definition of the covariant basis (##Z_{i}##) as follows:
$$Z_{i} = \frac{\delta \textbf{R}}{\delta Z^{i}}$$
Then, the derivative of the covariant basis is as follows:
$$\frac{\delta Z_{i}}{\delta Z^{j}} = \frac{\delta^2 \textbf{R}}{\delta Z^{i} \delta Z^{j}}$$
Which is also equal to the following:
$$\frac{\delta Z_{i}}{\delta Z^{j}} = \Gamma^{k}_{i j} Z_{k}$$
Such that:
$$\frac{\delta^2 \textbf{R}}{\delta Z^{i} \delta Z^{j}}=\Gamma^{k}_{i j} Z_{k}$$
(which is one way we know that ##i## and ##j## commute)
Then if we take the derivative of ##\frac{\delta Z_{i}}{\delta Z^{j}}## with respect to ##Z^{k}##, is the following equation true?:
$$\frac{\delta^2 Z_{i}}{\delta Z^{j} \delta Z^{k}} = \frac{\delta^3 \textbf{R}}{\delta Z^{i} \delta Z^{j} \delta Z^{k}}$$
The reason I ask is to see if the following is true:
$$\textbf{Z}^{k} \left( \frac{\delta^2 \textbf{Z}_{j}}{\delta Z^{i} \delta Z^{n}} - \frac{\delta^2 \textbf{Z}_{i}}{\delta Z^{j} \delta Z^{n}} \right) = \textbf{Z}^{k} \left(\frac{\delta^3 \textbf{R}}{\delta Z^{i}\delta Z^{j} \delta Z^{n}} -\frac{\delta^3 \textbf{R}}{\delta Z^{i}\delta Z^{j} \delta Z^{n}} \right)=0$$
Such that:
