I Relationship between nuclear magnetic physics and Maxwell's demon
The discussion explores the potential relationship between nuclear magnetic resonance (NMR) and Maxwell's demon, a thought experiment related to thermodynamics and information theory. The inquiry highlights that while Maxwell's demon metaphorically addresses entropy reduction without work, nuclear spin systems could provide insights into quantum information and thermodynamics. However, the original poster has not found explicit connections in the literature linking NMR with Maxwell's demon. They express skepticism about the feasibility of using magnetic resonance to physically separate hot and cold spins. Overall, the relationship between these two areas remains largely unexplored in scientific research.
juliocastro
TL;DR Summary
I am trying to understand if there is any conceptual or theoretical connection between nuclear magnetic physics, especially nuclear magnetic resonance (NMR), and the idea of Maxwell's demon in thermodynamics and information theory.
Hello,
I have been studying nuclear magnetic physics, focusing on phenomena such as nuclear magnetic resonance (NMR), and I started wondering whether there is any relationship with the famous Maxwell's demon thought experiment.
Maxwell's demon is a conceptual idea often discussed in the context of thermodynamics and the physics of information. Nuclear magnetic physics, on the other hand, studies the interactions between nuclear magnetic moments and external magnetic fields, involving quantum mechanics and statistical physics.
My question is: is there any established or proposed connection between these two topics — for example, through theoretical analogies, implications for the second law of thermodynamics, or experiments inspired by the demon concept? Has such a relationship been explored in the scientific literature?
What I have considered so far:
  • Maxwell’s demon is a metaphor for processes that seem to lower entropy without doing work.
  • Nuclear spin systems can be used to investigate aspects of quantum information and thermodynamics.
  • I have not found explicit references linking NMR and Maxwell’s demon.
Any explanation, discussion, or references to research papers would be greatly appreciated.
I don’t see how they would be related. I don’t know of any way to physically separate hot and cold spins using MR.
Consider an extremely long and perfectly calibrated scale. A car with a mass of 1000 kg is placed on it, and the scale registers this weight accurately. Now, suppose the car begins to move, reaching very high speeds. Neglecting air resistance and rolling friction, if the car attains, for example, a velocity of 500 km/h, will the scale still indicate a weight corresponding to 1000 kg, or will the measured value decrease as a result of the motion? In a second scenario, imagine a person with a...
Scalar and vector potentials in Coulomb gauge Assume Coulomb gauge so that $$\nabla \cdot \mathbf{A}=0.\tag{1}$$ The scalar potential ##\phi## is described by Poisson's equation $$\nabla^2 \phi = -\frac{\rho}{\varepsilon_0}\tag{2}$$ which has the instantaneous general solution given by $$\phi(\mathbf{r},t)=\frac{1}{4\pi\varepsilon_0}\int \frac{\rho(\mathbf{r}',t)}{|\mathbf{r}-\mathbf{r}'|}d^3r'.\tag{3}$$ In Coulomb gauge the vector potential ##\mathbf{A}## is given by...
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (First part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8 and stuck at some statements. It's little bit confused. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. Solution : The surface bound charge on the ##xy## plane is of opposite sign to ##q##, so the force will be...
