Relationship between two matrices
trenekas
Hello. I need some help with one question about relationship of two matrices.
The task:
Suppose that I is identity matrix, u - is vector, u' is transposed vector, α - real number. It can be prove that inverse matrix of I+α*u*u' has similar form I+x*u*u'. The task is to find x.
I tried to calculate inverse of this matrix I+α*u*u', but first of all when i don't know dimension it is very difficult to calculate inverse matrix. I tried to take example when u is from R^2, but even then i can't calculate x.
Any help would be appreciate. Any hints or something else.
Instead of trying to calculate the inverse, why not assume the inverse is like I+x*u*u' and see what happens when you take the product?
$$(I+\alpha uu^T)(I+xuu^T)=?$$
ok i will try. thanks for help, Matterwawe!
$$(I+\alpha uu^T)(I+xuu^T)=I$$
$$(I+I*xuu^T+I*\alpha uu^T+\alpha uu^T*xuu^T=I$$
So after that
$$I*xuu^T+I*\alpha uu^T+\alpha uu^T*xuu^T=0$$
$$xuu^T+\alpha uu^T+\alpha uu^T*xuu^T=0$$
$$(x+\alpha) uu^T+\alpha*x (uu^T*uu^T)=0$$
$$(x+\alpha) uu^T=-\alpha*x (uu^T*uu^T)$$
And what's next? How can i express x?
$$(x+\alpha)/-\alpha*x =(uu^T)^{-1}(uu^T*uu^T)$$
$$-1/\alpha-1/x=(uu^T)^{-1}(uu^T*uu^T)$$
$$-1/x=(uu^T)^{-1}(uu^T*uu^T)+1/\alpha$$
From equation
follows with
$$uu^T*xuu^T = xu(u^Tu)u^T = x (u^Tu) uu^T$$ (u^Tu is a scalar)
the solution of your question:
$$x = -\alpha / (1+\alpha u^Tu)$$
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
