Relationship of Modulus to thermal expansion
In summary, the conversation discusses the relationship between expected thermal expansion of a uv cured polymer within a rigid cylinder and a modulus specification, with a focus on the change in refractive index and the availability of expansion coefficients. The conversation also talks about the importance of using correct terminology and provides steps for solving the problem. Additionally, simple formulas involving thermal expansion coefficient and Young's modulus are shared for better understanding.
joeaccetta
I'm trying to figure out how to relate expected thermal expansion of a uv cured polymer within a rigid cylinder to a modulus specification. The issue is the expected change in refractive index due to thermal expansion. The expansion coefficients are not available. Anybody have an idea. Do greater specified moduli lead to increased or decreased expansion?
The thermal coefficient of expansion is one property. It describes how much an unconstrained object changes size with temperature change.
The modulus of elasticity, AKA elastic modulus, AKA Young's modulus, describes how much an object changes size with stress change.
You need to use the correct terms to avoid confusion.
If a polymer is constrained inside a rigid cylinder, then there is no thermal expansion. That is a simple problem to solve. Step 1: Calculate thermal expansion from temperature change. Step 2: Calculate stress to force the part back to its original size. Step 3 (optional): Calculate the force to get that stress.
One good way to get a better understanding of the relationships is to do the calculations for one polymer, then repeat for a different polymer with different properties.
You didn’t say which modulus you mean but I’ll also assume that it’s just Young’s modulus and share simple formulas involving thermal expansion coefficient and aforementioned modulus of elasticity: $$\Delta L= \alpha L_{0} \Delta T$$ $$\varepsilon=\frac{\Delta L}{L_{0}}$$ $$E=\frac{\sigma}{\varepsilon}$$ $$\sigma=E \varepsilon=E \alpha \Delta T$$
Thanks. Unfortunately, the particular modulus was not specified.
Thanks. Unfortunately the particular modulus is not specified but probably Youngs.
Thank you
FAQ: Relationship of Modulus to thermal expansion
What is the relationship between modulus and thermal expansion?
The relationship between modulus and thermal expansion is that as the temperature of a material increases, its modulus (or stiffness) decreases, causing it to expand. This is due to the increased vibration of molecules at higher temperatures, which creates more space between them and causes the material to expand.
How does thermal expansion affect the modulus of a material?
Thermal expansion causes the modulus of a material to decrease, making it less stiff. This is because as the material expands, the distance between molecules increases, making it easier for them to move and reducing the overall stiffness of the material.
Can thermal expansion cause a material to become weaker?
Yes, thermal expansion can cause a material to become weaker. As the material expands, the distance between molecules increases, making it easier for them to move and reducing the overall stiffness of the material. This can lead to a decrease in the material's strength and potentially cause it to fail.
How does the modulus of a material affect its thermal expansion?
The modulus of a material has an inverse relationship with its thermal expansion. This means that as the modulus of a material increases, its thermal expansion decreases. This is because a higher modulus indicates a stiffer material, which is less affected by changes in temperature.
Can the relationship between modulus and thermal expansion be used to predict a material's behavior?
Yes, the relationship between modulus and thermal expansion can be used to predict a material's behavior. By understanding how a material's modulus changes with temperature, we can anticipate how it will expand or contract and how it will respond to changes in its environment. This information is important for designing and engineering materials for specific applications.
20K
10K
