- #71
starthaus
- 1,568
kev said:It means the same thing as
[tex] \frac {d^2x'}{dt'^2}[/tex]
when dx' = dx, as it does in this case.
:lol:
which is unfortunate, because that is exactly what you derive in the final expression (6) in your blog.starthaus said:[tex] \frac {d^2x}{dt'^2}[/tex] means nothing.
kev said:which is unfortunate, because that is exactly what you derive in the final expression (6) in your blog.
starthaus said:Nope. [tex]\frac{d^2x}{dt^2}[/tex]. New glasses, perhaps?
kev said:You effectively derive:
[tex]\frac{d^2x}{dt^2} = \gamma^{-2}\frac{d^2x}{dt'^2}[/tex]
in expression (6) of your attachment, although you probably don't realize that.
You wrote such frame-mixing nonsense at step (5) when you derive the velocity transformation as:kev said:You effectively derive:
starthaus said:I would never write such frame-mixing nonsese.
kev said:You wrote such frame-mixing nonsense at step (5) when you derive the velocity transformation as:
[tex]\frac{dx}{dt} = \gamma^{-1}\frac{dx}{dt'}[/tex]
Jorrie said:I have a feeling that the reason behind this 'brutal' argument is a miscommunication. Starthaus's full equations treat the general solution of rotating to Cartesian coordinate transformations. In this case, saying that dx' and dx are equivalent is not valid.
Kev and myself were mainly interested in one point only, say when omega=0,
dx' and dx are momentarily equivalent.
Sorry, I actually meant when [itex]\theta = 0[/itex], where [itex]\omega=d\theta/dt[/itex]starthaus said:[tex]\omega[/tex] cannot be ever zero, the frame is totating.
Jorrie obviously meant that when the angle (theta or phi or whatever you choose to call it) between the x axes of the two frames is zero and by the definition given in this link that you gave http://arxiv.org/PS_cache/gr-qc/pdf/9904/9904078v2.pdf this occurs when t' =0.starthaus said:[tex]\omega[/tex] cannot be ever zero, the frame is totating.
dx' and dx are momentarily equivalent.starthaus said:This never happens. Look at the expression of dx, it is a function of (dx',dy',t')
Jorrie said:Sorry, I actually meant when [itex]\theta = 0[/itex], where [itex]\omega=d\theta/dt[/itex]
It is perhaps time that you clear up your attachment - the first line of your equations [5] of "Uniformly Rotating Frames" does use the contentious 'mixing of frames' (dx/dt').
It would also be immensely helpful to all around here (especially me as an engineer, no mathematician) if you would correct the typo and complete equations [6]...
kev said:Jorrie obviously meant that when the angle (theta or phi or whatever you choose to call it) between the x axes of the two frames is zero and by the definition given in this link that you gave http://arxiv.org/PS_cache/gr-qc/pdf/9904/9904078v2.pdf this occurs when t' =0.
It does happen. At time t' = 0, the axes are aligned and x = x' = 0 and y = y' =0.
By expression (4) of your attachment, when t' = 0, all the terms containing [itex]sin(y\omega t')[/itex] vanish and the term containing y' vanishes too, leaving
[tex]dx = dx'cos(0) = dx'[/tex].
Although that seems trivial, the same is not true for dy at time t'=0.
The dy equation in expression (4) becomes:
[tex]dy = \gamma dy' +R\gamma\omega dt'[/tex]
DaleSpam said:I hesitate to get involved in a good sparring match, but I have an old Mathematica notebook on relativistic uniform circular motion using four-vectors. I could post the results here if that would be helpful in any way.
starthaus said:I think that it is probably best to let kev work out the answers on his own. Only this way will he learn, giving away the answers is not the best way to teach somebody. He has been given all the tools, it is now up to him to complete the derivation.
That tells me that the x and y components are changing over time, but because of the circular symmetry and because the rotation is uniform and constant, the angular velocity, centripetal force, centripetal acceleration and gamma factor all remain constant over time and for any any angle theta and those are the physical quantities jorrie and I are interested in. Your equations seem unable to determine those quantities.kev said:[tex]dx = dx'cos(0) = dx'[/tex].
starthaus said:True, it happens in ONE PARTICULAR case. It does NOT happen in ANY other INFINITE number of cases. What does this tell you?
starthaus said:Do you still claim that you can use the expressions derived from Lorentz transforms for translational motion?
In particular, at t′ = 0 these transformations ... coincide with the ordinary Lorentz boost at t′ = 0 for the velocity in the y-direction.
Therefore, for a small range of values of t′, the transformations (6)-(7) can be approximated by the ordinary Lorentz boosts (see (19)). From this fact we conclude that if a moving rigid body is short enough, then its relativistic contraction in the direction of the instantaneous velocity, as seen from S, is simply given by L(t) = L′/(t), i.e., it depends only on the instantaneous velocity, not on its acceleration and rotation. (“Short enough” means that L′ ≪ c2/a′ k, where a′k is the component of the proper acceleration parallel to the direction of the velocity [11]).
By a similar argument we may conclude that an arbitrarily accelerated and rotating observer sees equal lengths of other differently moving objects as an inertial observer whose instantaneous position and velocity are equal to that of the arbitrarily accelerated and rotating observer.
kev said:This thread is not just about "teach kev a lesson". It's primary objective is to discuss the issues involved in relativistic centripetal force and acceleration in a way that might be useful for members of this forum. If that means I, you, Jorrie or anyone else learns something along the way, then all well and good. It is not just about your ego.
A think a worthy secondary objective would be debug the document you presented in your blog,
starthaus said:Your exercise is to express [tex] \frac {d^2x}{dt^2}[/tex] as a function of [tex] \frac {d^2x'}{dt'^2}[/tex]. I gave you all the tools to do that correctly.
starthaus said:I am quite sure that you and kev can complete expressions (6). I left them unfiinished on purpose, to lead you to the correct results and to teach you the correct way of solving this problem. If I give you the result ready made, kev will continue to find imaginary errors. Much better if I guide you to finding it.
kev said:You have not obtained [tex] \frac {d^2x'}{dt'^2}[/tex] in your document. All you have done is taken the derivative of x with respect to time twice and then transformed the result by converting dt to dt' using dt = gamma(dt'), What you have failed to do, is convert dx to dx' using dx = f(dx') where f is the long function inplicit in expression (4) of your document.
It is easy to complete expression (6) because it is obvious from the terms you have completed and from the method you use in obtaining expression (5), that all you are doing is dividing each term by [itex]\gamma dt'[/itex]. The completed expressions are (as far as I can tell):
[tex]\frac{d^2x}{dt^2}=\gamma^{-2}\left(\frac{d^2x'}{dt'^2}\cos(\gamma\omega t')-\gamma\omega\sin(\gamma\omega t') \frac{dx'}{dt'}-\gamma\frac{d^2y'}{dt'^2}\sin(\gamma\omega t')-\frac{dy'}{dt'}\gamma^{2}\omega\cos(\gamma\omega t') - \frac{d}{dt'}R\gamma\omega\sin(\gamma\omega t')\right)[/tex]
[tex]\frac{d^2y}{dt^2}=\gamma^{-2}\left(\frac{d^2x'}{dt'^2}\sin(\gamma\omega t')+\gamma\omega\cos(\gamma\omega t') \frac{dx'}{dt'}+\gamma\frac{d^2y'}{dt'^2}\cos(\gamma\omega t')-\frac{dy'}{dt'}\gamma^{2}\omega\sin(\gamma\omega t') + \frac{d}{dt'}R\gamma\omega\cos(\gamma\omega t')\right)[/tex]
Note that for constant uniform rotation, the last term of each expression containg R probably vanishes,
Since the vote is split 50/50 I will appoint myself vice president and cast the deciding vote in favor of posting itkev said:I would be very interested in your contribution.
DaleSpam said:Since the vote is split 50/50 I will appoint myself vice president and cast the deciding vote in favor of posting it
So throughout this I will use the convention that the time coordinate is the first coordinate and that timelike intervals squared are positive. So given a wheel centered at the origin and rotating about the z axis in a counter clockwise direction we can describe the worldline for any particle on the rim by:
[tex]\mathbf s =(ct,\; r \; cos(\phi + \omega t),\; r \; sin(\phi + \omega t),\; 0)[/tex]
The four-velocity is given by:
[tex]\mathbf u=c \frac{d\mathbf s/dt}{|d\mathbf s/dt|}=(\gamma c,\; -\gamma r \omega \; sin(\phi + \omega t),\; \gamma r \omega \; cos(\phi + \omega t),\; 0)[/tex]
where |\mathbf x| indicates the Minkowski norm of the four-vector x and [itex]\gamma=(1-\frac{r^2 \omega^2}{c^2})^{-1/2}[/itex]
The four-acceleration is given by:
[tex]\mathbf a=c \frac{d\mathbf u/dt}{|d\mathbf s/dt|} = (0,\; -\gamma^2 r \omega^2 \; cos(\phi + \omega t),\; -\gamma^2 r \omega^2 \; sin(\phi + \omega t),\; 0 ) [/tex]
So the magnitude of the four-acceleration (which is frame invariant and equal to the magnitude of the proper acceleration) is given by:
[tex]|\mathbf a|^2=-\gamma^4 r^2 \omega^4[/tex]
That is what I had in my Mathematica file, but I certainly can go from there or explain things if either of you have questions or requests.
No. Since,[tex]\gamma=(1-\frac{r^2 \omega^2}{c^2})^{-1/2}[/tex] the condition [itex]\gamma=1[/itex] would imply [itex]\omega=0[/itex] which is not true in general.starthaus said:Careful, see here. There is the additional condition [tex]\gamma=1[/tex] that must not be overlooked.
I deliberately didn't do any Lorentz transforms nor did I look at any other reference frame.starthaus said:We've been over this, this is exactly the same as pervect's post. The subject of the discussion is the appropiate transforms between frames (see post #3). Lorentz transforms for translation are not appropiate for describing rotation. kev is almost done with learning how to use the Lorentz transforms for rotation.
Thanks DaleSpam, I should have voted for it - I have been asking Starthaus for his treatment before.DaleSpam said:Since the vote is split 50/50 I will appoint myself vice president and cast the deciding vote in favor of posting it
DaleSpam said:I deliberately didn't do any Lorentz transforms nor did I look at any other reference frame.
Although a boost is not a spatial rotation you can always find a momentarily co-moving inertial frame (MCIF) for any event on any particle's worldline. This frame will be related to the original frame via a Lorentz transform. In such a frame the particle will only be at rest for a moment, hence the term "momentarily co-moving". So you cannot use a Lorentz transform to find a (non-instantaneous) rest frame for a particle in general, but there is a lot of useful parameters you can obtain from the MCIF.
I don't know how kev was using it.
Jorrie said:Thanks DaleSpam, I should have voted for it - I have been asking Starthaus for his treatment before.
Anyway, it seems that your magnitude of the proper acceleration answers the original question of the OP: the relativistic centrifugal force, measured in the way that kev described.
To me it does not seem as if Starthaus's treatment answered that question, but rather a different one on coordinate transformations for rotating frames. I am sure that it is useful in its own right and can possibly be extended to answer the original question.
Jorrie said:To me it does not seem as if Starthaus's treatment answered that question, but rather a different one on coordinate transformations for rotating frames. I am sure that it is useful in its own right and can possibly be extended to answer the original question.
DaleSpam said:No. Since,[tex]\gamma=(1-\frac{r^2 \omega^2}{c^2})^{-1/2}[/tex] the condition [itex]\gamma=1[/itex] would imply [itex]\omega=0[/itex] which is not true in general.
I have never heard of the Lorentz transform for rotating frame. AFAIK the Lorentz transform transforms between different inertial frames, not between an inertial frame and a rotating frame.starthaus said:you need to start from the Lorentz transforms for rotating frames.
The Minkowski norm of the four-acceleration is frame invariant. So it does not matter which frame you calculate it in; it will be the same in all frames. If those factors of [itex]1-r^2\omega^2/c^2[/itex] appear in one frame they must appear in all frames.starthaus said:No, it doesn't mean that, it only means that the comoving frame (for which you are calculating the proper acceleration) is characterized by [itex]\omega=0[/itex] . Because the frame is co-moving with the rotating object.
So, you should have obtained the proper acceleration magnitude as:
[tex]a=r\omega^2[/tex]
kev said:OK, if I understand correctly, because of the t' contained in the cos and sin functions in the last terms, the expressions for (6) should be:
[tex]\frac{d^2x}{dt^2}=\gamma^{-2}\left(\frac{d^2x'}{dt'^2}\cos(\gamma\omega t')-\gamma\omega\sin(\gamma\omega t') \frac{dx'}{dt'}-\gamma\frac{d^2y'}{dt'^2}\sin(\gamma\omega t')-\frac{dy'}{dt'}\gamma^{2}\omega\cos(\gamma\omega t') - R\gamma^2\omega^2\cos(\gamma\omega t')\right)[/tex] (Eq6x)
[tex]\frac{d^2y}{dt^2}=\gamma^{-2}\left(\frac{d^2x'}{dt'^2}\sin(\gamma\omega t')+\gamma\omega\cos(\gamma\omega t') \frac{dx'}{dt'}+\gamma\frac{d^2y'}{dt'^2}\cos(\gamma\omega t')-\frac{dy'}{dt'}\gamma^{2}\omega\sin(\gamma\omega t') - R\gamma^2\omega^2\sin(\gamma\omega t')\right)[/tex] (Eq6y)
Is that correct?
If they are correct, then when t' = 0, [itex]\sin(\gamma\omega t') = 0[/itex] and [itex]\cos(\gamma\omega t') = 1[/itex] and the equations simplify to:
DaleSpam said:I have never heard of the Lorentz transform for rotating frame. AFAIK the Lorentz transform transforms between different inertial frames, not between an inertial frame and a rotating frame.
DaleSpam said:The Minkowski norm of the four-acceleration is frame invariant. So it does not matter which frame you calculate it in; it will be the same in all frames. If those factors of [itex]1-r^2\omega^2/c^2[/itex] appear in one frame they must appear in all frames.
