In summary, the conversation discusses the concept of gravitational potential energy and its relation to the rest and relativistic mass of an object. It is mentioned that special relativity is not compatible with Newtonian gravity and that General Relativity has multiple concepts of system energy, but none of them include the concept of potential energy. It is also noted that in the case of test masses, there is a notion of total energy that remains constant along the path of the object, known as "The Energy at Infinity". However, this concept cannot be applied to objects that are not test masses.
sha1000
123
Hello everyone,
Any object has a gravitational potential energy as a function of the distance from the Earth (R). Does this energy depend only on the rest mass of the object; or one must take into account it's relativistic mass?
In other words, if we imagine two identical bullets on the top of a building with different initial velocities ( towards the earth); will they have the same potential energy?
You cannot apply concepts of Newtonian gravity on special relativity.
Likes sha1000, pervect and jbriggs444
Gravitational potential energy is a Newtonian concept. General relativity has various (more than one) concept of system energy, but there's no way to split the system energy up into kinetic and potential energy.
As Orodruin mentions, special relativity is not compatible with Newtonian gravity, this was one of the primary reasons that prompted Einstein to develop General Relativity. So this means the question as phrased cannot be answered, because one needs General Relativity to attempt an answer it, but General Relativity does not have the concept of "potential energy" mentioned in the question.
In the case where the "bullets" are assumed to be test masses, one can compute a meaningful notion the total energy of each of the bullets. If the bullets are free-falling (following geodesic paths), there is a suitable notion of "total energy" that remains constant along the entire path of the bullet, a notion called "The Energy at Infinity" by MTW in their textbook "Gravitation". From this, one can compute the impact velocity of the bullets relative to the ground as measured by an observer on the ground. This requires a working knowledge of General Relativity to follow the details of the calculation, however.
In the more general case where the bullets are not test masses, the above approach would not work. Getting into further details about this case would be overly complex for the point I'm trying to make.
Likes sha1000
Let me add an online link to the formulas that I mentioned in my last post: https://www.fourmilab.ch/gravitation/orbits/. I happen to know that these formulas are essentially identical to the ones in MTW's text, "Gravitation", but the interested reader who has access to the text might want to study the original. The web-page is more convenient and accessible, though.
The case given in the webpage includes cases where the velocity is not central, it applies to orbiting test masses. To get the equations for when the motion is purely radial, set the angular momentum L to zero.
Then we wind up with the expression in geometric units assuming L=0 as:
$$\left( \frac{dr}{d\tau} \right) ^2 + 1-\frac{2M}{r} = E^2$$
where ##E^2## is a constant of motion related to energy, r is the Schwarzschild radial coordinate, ##\tau## is proper time, and M is the mass of the massive body in geometric units. From memory, M for the sun is about 1500 meters.
Note that ##dr / d\tau## is related to velocity, but further work would be needed to convert it into the velocity as measured by a co-located inertial observer. dr is not the same as distance measured by a co-located inertial observer due to the metric coefficients of the Schwarzschild metric, and ##d\tau## is the change in proper time, not the change in coordinate time.
Basically, we can use "conservation of energy" arguments in the case of a test mass falling into a massive body to come up with meaningful equations, but the details of how we do this are different in General relativity than they are in Newtonian mechanics. The simple approach outlined above won't work if the bodies are not test masses, one way of describing the issue is to say that gravitational radiation is emitted when the infalling body is not a test mass, and the problem becomes significantly more complex.
Thank you for your response.
I understand. Let's forget the notion of the potential energy and return to the example of the 2 bullets.
They have the same rest mass and the same distance from earth. We know the initial velocities of the bullets. We can calculate their relativistic masses: m = m0/sqrt(1 - v2), and their energies: E=mc2
We are also able to measure the final velocities of the bullets at the bottom of the tower; and calculate corresponding relativistic masses and energies.
Here is the question: if we calculate the energy differences between the top and the bottom of the tower, will we obtain the same value for the 2 bullets (with different initial velocities)?
The energy measured by a observer at constant altitude is ##g_{\mu\nu}U^\mu P^\nu=m_0g_{\mu\nu}U^\mu V^\nu##, where ##U^\mu## is the four-velocity of an observer at constant altitude, and ##P^\nu## is the four-velocity of the bullet, which is equal to the its rest mass, ##m_0##, times its four velocity ##V^\nu##. Since, in Schwarzschild coordinates, ##U^t=1/\sqrt{g_{tt}}## is the only non-zero component of ##U## and the metric is diagonal, the measured energy is ##m_0\sqrt{g_{tt}}V^t##.
Of course, ##g_{tt}=1-R_s/r##. And for a geodesic ##V^t=dt/d\tau=E_\infty/(1-R_s/r)##, where ##E_\infty## is the energy per unit mass at infinity (see 7.43 in Sean Carroll's GR lecture notes, for example - he uses just ##E## for what I've called ##E_\infty##, but you've used that for something else). Thus the measured energy is ##m_0E_\infty/\sqrt{1-R_s/r}## and the energy difference you are asking about is $$\Delta E=m_0E_\infty\left(\frac 1{\sqrt{1-R_s/r_1}}-\frac 1{\sqrt{1-R_s/r_2}}\right)$$where the bullet has fallen from ##r_2## to ##r_1##.
The initial velocity of the bullet is encoded in ##E_\infty##. The ##\gamma## factor measured by the hovering observer at ##r_2## is actually given by ##\gamma=g_{\mu\nu}U^\mu V^{\nu}=E_\infty/\sqrt{1-R_s/r_2}##, so we can write the energy difference as$$\Delta E=m_0\gamma\left(\frac{\sqrt{1-R_s/r_2}}{\sqrt{1-R_s/r_1}}-1\right)$$I would strongly resist using the term "relativistic mass" but, assuming I haven't mucked that up, it would appear that the "energy gain" is proportional to ##\gamma m_0##, yes.
Likes sha1000
Thank you so much for your answer and your time. It is so complete that I don't have any further questions.
Related to Relativistic mass and gravitational potential
1. What is relativistic mass?
Relativistic mass, also known as "rest mass", is the mass of an object as measured by an observer who is at rest relative to the object. It takes into account the effects of special relativity, such as time dilation and length contraction.
2. How is relativistic mass different from rest mass?
Relativistic mass is different from rest mass because it takes into account the effects of special relativity, while rest mass does not. Relativistic mass increases with an object's velocity, while rest mass remains constant.
3. Can relativistic mass be greater than rest mass?
Yes, relativistic mass can be greater than rest mass. This happens when an object is moving at a high velocity, close to the speed of light. The increase in mass is due to the energy associated with the object's motion.
4. How does gravitational potential affect relativistic mass?
Gravitational potential affects relativistic mass by causing time dilation. In areas of high gravitational potential, time passes more slowly, which results in an increase in relativistic mass. This is known as the gravitational redshift.
5. Can gravitational potential cause a change in an object's rest mass?
No, gravitational potential does not cause a change in an object's rest mass. Rest mass is an intrinsic property of an object and remains constant regardless of its location or gravitational potential. Only relativistic mass is affected by gravitational potential.
