Relativistic Mechanics (momentum)
The discussion revolves around calculating the momentum of an electron with a kinetic energy of 1.00 MeV using relativistic mechanics. The user initially suspects an error due to an unexpectedly large result and attempts to apply the equation E² = m²₀c⁴ + p²c². After several calculations, they find a discrepancy when plugging values back into the equation, leading to confusion over the terms. Ultimately, they correct their approach and acknowledge a mistake in their calculations, clarifying that they had overlooked a crucial component in the equation. The conversation highlights the importance of careful term management in relativistic momentum calculations.
Cmertin
I did the problem, though I don't think that it is right. I think that the number is to big so I think I might have screwed up somewhere though I don't know where.
What is the momentum (in units of MeV/c) of an electron with a kinetic energy of 1.00 MeV?
Energy_{kinetic} = Energy
E^{2} = m^{2}_{0}c^{4} + p^{2}c^{2}
c = 3E8 m/s
m0 = rest mass = .511 MeV c^{-2}
p^{2}c^{2} = m^{2}_{0}c^{4} - E^{2}
p^{2}c^{2} = (.511 MeV c^{-2})^{2}(3x10^{8}m/s)^{4} - (1.00 MeV)^{2}
p^{2}c^{2} = 2.35E16 MeV^{2}
pc = 1.53E8 MeV
p = 1.53E8 MeV c^{-1}
Firstly, p^{2} c^{2} = E^{2} - m_{0}^{2} c^{4} - rearrange your terms carefully.
Next, ( 0.511 MeV c^{-2} )^{2} ( c^{4} ) = 0.511 MeV^{2}
Note that the c^{-2} is also squared!
OK, thanks for your help, though the left and the right side of the equations are not matching up when I go to plug the answers back in.
I got that p = .8596 MeV c-1
Plugging it back in, I get
p2c2 = E - m02c4
(.8596 [STRIKE]c-1[/STRIKE])2[STRIKE]c2[/STRIKE] = 1 - (.26112 MeV2 [STRIKE]c-4[/STRIKE])[STRIKE]c4[/STRIKE]
.7389 = .2611
Err..it should be 0.7389 = 1 - 0.2611 *points to your 2nd last equation* which is coherent.
My bad, I'm a retard today... Thanks for your help (I forgot that the 1 was there...)
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
