- #36
Physicsguru
- 120
Healey01 said:Ok, you got
[tex] \frac{dt}{dU} \frac{d^2S}{dt^2} = - \frac{dS}{dt} \frac{d}{dt} (\frac{dt}{dU}) [/tex]
now what are you trying to show with it? You just go back to standard definition of temperature.
Actually, I'm just trying to answer his question mathematically.
The intuitive answer is this: if the temperature of the vacuum were absolute zero kelvin in reality, and an object immersed in the vacuum had to eventually reach thermal equilibrium with its surroundings, then eventually its temperature would reach zero and truly be constant. On the other hand, the temperature of the vacuum really isn't zero (nor is it constant), so in order for an object in the vacuum to have a constant temperature by eventually reaching thermal equilibrium with the vacuum, the temperature of the vacuum would also have to be constant, and isn't. There are a sea of photons there.
Regards,
Guru
