Removing impurities via recrystallization
  • Thread starter Thread starter scienceboy2000
    Impurities
When recrystallizing compound*, the choice of solvent is crucial for effectively removing impurities. The initial use of water, which dissolves both compound* and its impurity, leads to crystallization of both, resulting in impure crystals. A better approach involves using a multi-solvent system, where a small amount of water creates a saturated solution, followed by the gradual addition of acetone to induce precipitation. The presence of water in the acetone may affect the precipitation process, but careful control of the acetone addition can optimize purity. Washing the solid with acetone is also suggested as a method to further reduce impurities.
scienceboy2000
I have read online that suppose I am trying to purify compound_A, which contains an impurity, let's call that compound_B, that the solvent that I choose for recrystallization must either:
1) dissolve compound_A but not compound_B, so that compound_B can be filtered out after dissolving compound_A in the solvent
or
2) Both compound_A and compound_B must both be completely soluble in the solvent (at least when it`s hot) so that when crystallization starts to occur, compound_B remains in the solvent.
I have a question. I do my own experiments and I am trying to recrystallize a compound, let`s call it compound*. I know that compound* is impure. The solvent I am using is water. Now, the hot water dissolves both compound* and its impurity. So according to what I read online I would expect the impurity remain in the solvent while crystallization occurs (i.e. while the solution is cooling to room temperature). However, after leaving the solution for several hours, there is no more solvent. That is, everything has been crystallized. Does this mean that the resulting crystals are just as impure as my original compound? Does it contain the original impurity that I was trying to get rid of?
All help would be appreciated.
Chemistry news on Phys.org
Yes, if you dried it out nothing has changed. Correct procedure calls for getting rid of solvent containing mostly impurities (and as small amount of the compound you are purifying as possible). Finding correct solvent and correct conditions is not always easy.
I guess I could use a multi-solvent system. My compound is extemely soluble in water and so is its impurity, even at room temperature, so water is not a good solvent for this. But my compound is completely insoluble in acetone while its impurity is soluble in acetone. So I could dissolve my compound in the smallest amount of water possible, creating a saturated solution, then slowly add acetone to force it to precipiate out. My question is, do I add acetone until precipitation starts, then leave it to its own devices? Or do I add acetone until precipitation completely stops?
Also, my acetone will most definitely not be anhydrous. Let's assume that there's a 5% concentration of water in the acetone. Will this effect my plan to force precipitation via adding acetone?
Why don't you just wash the solid with the acetone?
Thread 'How to make Sodium Chlorate by Electrolysis of salt water?'
I have a power supply for electrolysis of salt water brine, variable 3v to 6v up to 30 amps. Cathode is stainless steel, anode is carbon rods. Carbon rod surface area 42" sq. the Stainless steel cathode should be 21" sq. Salt is pure 100% salt dissolved into distilled water. I have been making saturated salt wrong. Today I learn saturated salt is, dissolve pure salt into 150°f water cool to 100°f pour into the 2 gallon brine tank. I find conflicting information about brine tank...
Engineers slash iridium use in electrolyzer catalyst by 80%, boosting path to affordable green hydrogen https://news.rice.edu/news/2025/engineers-slash-iridium-use-electrolyzer-catalyst-80-boosting-path-affordable-green Ruthenium is also fairly expensive (a year ago it was about $490/ troy oz, but has nearly doubled in price over the past year, now about $910/ troy oz). I tracks prices of Pt, Pd, Ru, Ir and Ru. Of the 5 metals, rhodium (Rh) is the most expensive. A year ago, Rh and Ir...
