Represent sinh2x as power series
synergix
find the first three non zero terms of a power series representation of f(x)= sinh 2x
seems easy enough do I just substitute 2x for x?
so sinh 2x= 2x + 8x3/3! + 32x5/5!
Yes that should be correct.
Thanks I messed this one up on a test because I forgot to put the formula on my cheat sheet but damn that was easy
You didn't really need to have the formula on your cheat sheet if you know how to differentiate sinh(2x). Just use the general formula for a Taylor series.
Or if you know how to express sinh(x) in terms of exponentials, and you know the Taylor series for exp(x).
Well I tried using Taylor series and am happy to say that was also very easy and much more satisfying. Those Taylor series aren't so bad after all:)
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
