- #36
olgerm
- 35
This is not what OP meant by linear version of the Faraday paradox in his original post, because conductor and magnet are not moving together in your setup.artis said:Look at this simple "railgun" which is basically a linear homopolar motor/Faraday disc, if one applies current to the rails the third shunting rod moves along the rails, but if one puts a voltmeter across the rails, puts a magnet under or above the rails and moves the third rod by hand the voltmeter should read DC voltage output because imagine the rails , voltmeter and moving rod form a rectangular loop that is electrically closed , as you move the rod you change the cross-sectional area of the loop in other words you change the amount of B field lines through the loop which results in generated current in the loop.
greswd said:This has made me curious about the linear version of the Faraday paradox.
A conductor placed atop a magnet, both at rest in one scenario. In another, both moving together in uniform linear motion.
