Resistivity calculation from two-probe resistance measurement of sheet
Calculating resistivity from two-probe resistance measurements requires consideration of contact area geometry, particularly when using point contacts, which theoretically yield infinite resistance. The discussion highlights that the perimeter of each contact area is crucial for accurate calculations. An exact solution can be derived using elliptical equipotentials around each contact area, with the central ellipse acting as the bisector between them. The potential distribution is related to the logarithmic ratio of distances to the centers of these ellipses. Understanding these factors is essential for accurate resistivity calculations.
no_einstein
New user has been reminded to please always show their work on schoolwork problems.
You make a two-probe resistance measurement (probe spacing S) of an infinite sheet (thickness t) of a high-resistance material. How do you calculate the resistivity of the material?
R = ohm, rho = ohm*m
I'm really not sure. Obviously I can get the units right with Resistance * thickness, but I assume there's a correction factor here that I can't find anywhere?
I studied this once out of my own interest. I concluded that as stated in post #1 it makes no sense. What you also need to know is the perimeter of each contact area. With point contacts the theoretical resistance is infinite.
If we take those areas to be elliptical, we can have an exact solution with nested elliptical equipotentials around each contact ellipse. The 'central ellipse', i.e. where the one family transmutes into the other, is the perpendicular bisector of the two contact areas. The potential at any point is proportional to the logarithm of the ratio of distances to the 'centres', i.e. where the two families of ellipses would shrink to zero.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
