Resists for etching Aluminium with NaOH
  • Thread starter Thread starter CWatters
A user is seeking a cost-effective DIY method to etch holes in 0.3mm aluminum sheets using 5-10% sodium hydroxide (NaOH) and is exploring various resist materials. Suggested resists include enamel paint, acrylic paint, Sharpie ink, vinyl masks, and bitumen-based paint, with bitumen being the most effective so far. The user is considering 2-part epoxy paint and high pH surface paints as potential options, although they are difficult to source in small quantities. There is also a need for a solvent to remove the resist, with suggestions including acetone and IPA. The discussion raises questions about the necessity of chemical methods versus simpler mechanical approaches for such thin aluminum.
CWatters
Homework Helper
I'm trying to find a cheap DIY method to etch holes of various shapes through 0.3mm Aluminium sheet using 5-10% Sodium Hydroxide. The idea is to apply a resist to the Aluminium then selectively ablate it off using a diode laser cutter and then dissolve away the Aluminium using Sodium Hydroxide. By cheap I mean resists costing say £20 in small quantities.
The Internet has suggested various resists to try including...
Enamel paint (only survived seconds in the NaOH!)
Acrylic paint (only survived a short time in the NaOH)
Sharpie ink (too hard to remove it all with the laser)
Vinyl masks (adhesive dissolved by the NaOH allowing mask to come off)
Bitumen based paint (Best yet but finally came off before all the Aluminium was dissolved)
Nail varnish (not tried yet)
2 part Epoxy Paint (not tried yet)
Kapton tape with Acrylic adhesive (not sourced yet)
I also need to remove the resist using a solvent of some sort (Acetone, IPA, gasoline etc) although I suppose I could also laser it off.
So can any chemists suggest other resists or which to try next?
The 2 part Epoxy Paint is probably my best bet but it's not very convenient and hard to find in small quantities. 1K Epoxy paint in a can apparently isn't good enough.
Any suggestions?
Chemistry news on Phys.org
I am not a chemist, but if it was my project I would try a paint intended for high pH surfaces (such as masonry).
Such a coating might be hard on the aluminum, but I would hope that it lasts long enough for the NaOH and wash. I would think it would survive the NaOH itself without a problem.
As an example: https://www.millerpaint.com/product/ph-surfacer-interior-exterior-primer-2/
Thanks Scott, great suggestion.
Why are you resorting to chemical means rather than simply poking holes? 0.3 mm is just aluminium foil?
Thread 'How to make Sodium Chlorate by Electrolysis of salt water?'
I have a power supply for electrolysis of salt water brine, variable 3v to 6v up to 30 amps. Cathode is stainless steel, anode is carbon rods. Carbon rod surface area 42" sq. the Stainless steel cathode should be 21" sq. Salt is pure 100% salt dissolved into distilled water. I have been making saturated salt wrong. Today I learn saturated salt is, dissolve pure salt into 150°f water cool to 100°f pour into the 2 gallon brine tank. I find conflicting information about brine tank...
Engineers slash iridium use in electrolyzer catalyst by 80%, boosting path to affordable green hydrogen https://news.rice.edu/news/2025/engineers-slash-iridium-use-electrolyzer-catalyst-80-boosting-path-affordable-green Ruthenium is also fairly expensive (a year ago it was about $490/ troy oz, but has nearly doubled in price over the past year, now about $910/ troy oz). I tracks prices of Pt, Pd, Ru, Ir and Ru. Of the 5 metals, rhodium (Rh) is the most expensive. A year ago, Rh and Ir...
