I Resolution of observation telescopes?
The resolution of an observatory telescope is influenced by its objective lens diameter, with the resolving power calculated using the formula: resolving power = 11.25 seconds of arc/d. There is a distinction between high resolution with a larger field of view versus high resolution with a narrower field that requires extensive scanning to create full images. The Signal to Noise Ratio is crucial in determining how effectively a telescope can resolve multiple faint stars. A longer focal length allows for larger sensor elements, enhancing sensitivity, while a wider field necessitates smaller elements to maintain resolution. Ultimately, the effectiveness of a telescope's resolution depends on the total energy flux received by the sensor from the observed area.
LightningInAJar
TL;DR Summary
Observation telescope stats.
I was wondering how the resolution is of a observatory station and compare that to its field of view? Higher rez with larger field or higher rez with more narrow field but much more scanning across the sky to create full images?
Astronomy news on Phys.org
Likes hutchphd and berkeman
LightningInAJar said:
Summary:: Observation telescope stats.
I think your question could be based on a false dichotomy. You are not really comparing like with like. Resolution is not the only relevant factor in astronomy. Pushing the system to see (and resolve) as many stars as possible involves the good old Signal To Noise Ratio. Your two scenarios are including the implication that you want to scan a particular region of sky and not just to resolve two distant, faint objects. The diffraction limit is set by the diameter of the objective lens (at least, that's a major factor). If you use a long focus / narrow angle then your sensor can have bigger elements and, therefore more sensitivity to a given elemental angle of view.
But if you want to scan a wide field, either the focal length of the objective your sensor would need to be shorter and, to make use of this wider field, the element area would need to be less in order still to resolve the two faint objects and have room for many more on the image.
Otoh, you could stick with the original scope and scan it around. Apart from practical details, the longer time to get your big image by scanning the scope around would be very much of the same order as the extra exposure time you'd need to get high enough signals from your finer pitch sensor elements behind a wider angle lens.
That's probably a gross oversimplification but it's got to be based on the total Energy flux from each area of space onto a sensor.
Likes LightningInAJar, DaveE and Tom.G
I think this can be shown, using information theory, to be exactlly true. Please don't ask me to reproduce the argument.... it would require deep coherent thought.
Likes sophiecentaur
Is a homemade radio telescope realistic? There seems to be a confluence of multiple technologies that makes the situation better than when I was a wee lad: software-defined radio (SDR), the easy availability of satellite dishes, surveillance drives, and fast CPUs. Let's take a step back - it is trivial to see the sun in radio. An old analog TV, a set of "rabbit ears" antenna, and you're good to go. Point the antenna at the sun (i.e. the ears are perpendicular to it) and there is...
3I/ATLAS, also known as C/2025 N1 (ATLAS) and formerly designated as A11pl3Z, is an iinterstellar comet. It was discovered by the Asteroid Terrestrial-impact Last Alert System (ATLAS) station at Río Hurtado, Chile on 1 July 2025. Note: it was mentioned (as A11pl3Z) by DaveE in a new member's introductory thread. https://www.physicsforums.com/threads/brian-cox-lead-me-here.1081670/post-7274146 https://earthsky.org/space/new-interstellar-object-candidate-heading-toward-the-sun-a11pl3z/ One...
