Resolving forces in the direction perpendicular to a line
To resolve forces perpendicular to a line, it's essential to sketch the appropriate triangle for the forces F1 and F2. Using the sine or cosine rule can help in determining the components of these forces. The key is to focus on the forces that act perpendicular to the lever with respect to the fulcrum A. By accurately labeling the forces and applying basic trigonometry, the correct answers can be derived. Understanding these concepts is crucial for solving similar problems effectively.
Bolter
See below
N/A
Hi I'm very stuck on what to do for these 2 questions I got wrong
Can someone please help me on what triangle I need to sketch out in order to find the 2 components of forces for F1 and F2. I'm assuming you have to make use of the sine or cosine rule here
I'd be grateful for any help given! Thanks
What have you done so far?
Remember that what counts here are the actual forces that are perpendicular to the levers, all respect to the fulcrum A.
Likes Bolter
What are the horizontal and vertical components of force F1?
I actually managed to find the right answer at the end by drawing triangles and labelling the forces that are perpendicular to the line AB. Then with some basic trig I got the force needed
Likes Lnewqban
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
