Resonance Structures Chemistry: What is Potential Energy?
The discussion centers on the concept of potential energy in chemistry, particularly in relation to resonance structures. Potential energy in a chemical context is linked to the arrangement of electrons and nuclei within a molecule. Lower potential energy indicates greater stability, as it requires more energy to disrupt the molecular structure. This is analogous to a moon orbiting a planet; a closer orbit represents lower gravitational potential energy and increased stability, as it would take a significant force to alter that orbit. The conversation emphasizes the complexity of molecular interactions while aiming to explain these concepts in simple terms.
Johnleprekan
I was reading this article from Wikipedia on resonance structures:
http://en.wikipedia.org/wiki/Resonance_(chemistry )
What I do not understand is, what is meant by potential energy in terms of chemistry? In physics, potential energy is defined by location in a force field. What is it that determines potential energy in a compound or molecule? Is it the position of electrons to other electrons, electrons to nuclei? How does having lower potential energy make a molecule more stable? Explain in layman's terms please.
Chemistry news on Phys.org
erk.
Chemical potential energy is related to electromagnetic potential energy... it's just that molecules tend to be pretty complicated.
By analogy:
You can understand that a moon orbiting closer to a planet has a lower gravitational potential energy is also more stable - it takes a larger random knock to push that moon out of orbit? It's the same for the atoms in a molecule.
Thank you.
No worries - so long as you don't try using that to draw new conclusions you'll be fine.
In a bit some of the others will pop up and tell you where I'm taking horrible liberties in the name of being layman-friendly ;)
Thread 'How to make Sodium Chlorate by Electrolysis of salt water?'
I have a power supply for electrolysis of salt water brine, variable 3v to 6v up to 30 amps. Cathode is stainless steel, anode is carbon rods. Carbon rod surface area 42" sq. the Stainless steel cathode should be 21" sq. Salt is pure 100% salt dissolved into distilled water. I have been making saturated salt wrong. Today I learn saturated salt is, dissolve pure salt into 150°f water cool to 100°f pour into the 2 gallon brine tank. I find conflicting information about brine tank...
Engineers slash iridium use in electrolyzer catalyst by 80%, boosting path to affordable green hydrogen https://news.rice.edu/news/2025/engineers-slash-iridium-use-electrolyzer-catalyst-80-boosting-path-affordable-green Ruthenium is also fairly expensive (a year ago it was about $490/ troy oz, but has nearly doubled in price over the past year, now about $910/ troy oz). I tracks prices of Pt, Pd, Ru, Ir and Ru. Of the 5 metals, rhodium (Rh) is the most expensive. A year ago, Rh and Ir...
