Reverse saturation current and leakage current in a BJT
IS, or reverse saturation current, refers to the base-emitter junction's reverse current in a BJT, while ICBO is the collector-base reverse current, often considered leakage current. The confusion arises because both terms are sometimes used interchangeably, despite representing different junctions within the BJT. The collector-base junction's reverse saturation current is denoted as Ics, and the base-emitter junction's as Ies, which differ due to varying doping densities. Understanding these distinctions is crucial for accurate analysis of BJT behavior and characteristics. Clear differentiation in terminology is essential for effective communication in semiconductor theory.
anubhavsingh
TL;DR
What is the relation between reverse saturation current and leakage current in a BJT?
I have been studying Studying Donald Neamen's Electronic Circuits 4th edition and Sedra Smith's Microelectronics 7th edition for quite some time now. I have been self studying. After searching extensively on Internet as well as trying to understand from the books, I have not been able to differentiate between two quantities in the context of BJT.
These two quantities are: IS and ICBO
According to Sedra Smith, ICBO is the collector base reverse current and
Whereas IS is the saturation or scale current given by
I have been wondering are these two quantities same or share some relation between them because I find the name for both these quantities being used inter-changeably at many places which is quite confusing and I believe they are not the same.
Also, I am confused which current is being referred to when on Internet I find the term "reverse saturation current". Searching on Internet the term "reverse saturation current" gives two kinds of sources: one referring it as IS and the other referring it as ICBO Another similar quantity is ICBO.
References
Sedra Smith
Donald Neamen
anubhavsingh said:
Summary:: What is the relation between reverse saturation current and leakage current in a BJT?
References
Sedra Smith
Donald Neamen
Here it is. The *reverse saturation current*, "Is", is the reverse current of the base-emitter junction. This is denoted as "Is" in a diode, a 2 terminal device.
But a bjt has 3 terminals, & 2 p-n junctions. The collector base jcn is reverse biased when bjt is biased in its active region. Without base current, the emitter current is the collector base jcn reverse saturation current. This can be regarded a "leakage current". This is "Ics", the collector base reverse saturation current.
The base emitter jcn has a reverse saturation current denoted by "Ies". This value, Ies, generally differs from Ics since collector & emitter regions have differing doping densities. The value Ies is the reverse current in a reverse biased base emitter junction with collector open.
The parameter "Icbo", is collector to emitter current with an open base. This is often regarded as leakage, since a bjt having no input on the base emitter junction, ie zero bias, should ideally have zero collector current Ic.
But the reverse biased c-b jcn has a small reverse current, Ics per Shockley diode eqn, or Icbo per bjt circuit models. Data sheets display this Ics/Icbo value generally.
The problem with most semiconductor theory textbooks is that of denoting b-e jcn reverse saturation current as "Is". For a diode, Is is fine. But bjt has 2 junctions, each with its own "Is" parameter. Good concise authors differentiate these values by denoting them as "Ics", & "Ies", wrt to collector base & base emitter junctions.
I hope I've helped.
Likes anubhavsingh and berkeman
Thread 'I thought it was only Amazon that sold unsafe junk'
I grabbed an under cabinet LED light today at a big box store. Nothing special. 18 inches in length and made to plug several lights together. Here is a pic of the power cord: The drawing on the box led me to believe that it would accept a standard IEC cord which surprised me. But it's a variation of it. I didn't try it, but I would assume you could plug a standard IEC cord into this and have a double male cord AKA suicide cord. And to boot, it's likely going to reverse the hot and...
14K
9K
