Riemann Curvature Tensor in 2D
In summary, the conversation discusses the relationship between the Riemann curvature tensor and its contracted form in 2D. It is possible to reverse the contracted form to obtain the Riemann tensor, but this may not always result in the expected index-symmetries.
Woolyabyss
143
Show that the Riemann curvature tensor in 2d is given by ##R_{abcd} =\frac{R}{2}(g_{ac}g_{bd} - g_{ad}g_{bc}) ##
## R = R_{ab} g^{ab} ## and ## R_{ab} = R_{acb}^{c}##
Since in 2D the riemman curvature tensor has only one independent component, ## R = R_{ab} g^{ab} ## can be reversed to get the riemmann curvature tensor.
Write
## R_{ab} = R g_{ab} ##
Now
## R g_{ab} = R_{acbd} g^{cd}##
Rewrite this as
## R_{acbd} = Rg_{ab} g_{cd} ##
My issue is I'm not sure how they caught a second term? Any help would be appreciated.
Woolyabyss said:
Now
Rewrite this as
Your candidate Riemann tensor doesn't have the expected index-symmetries.
Generally, you can't undo a contraction to arrive at your last line.
There may be other expressions that lead to the same contracted term.
Related to Riemann Curvature Tensor in 2D
1. What is the Riemann Curvature Tensor in 2D?
The Riemann Curvature Tensor in 2D is a mathematical object that describes the curvature of a two-dimensional space. It is a tensor field that contains information about how the space curves at every point.
2. How is the Riemann Curvature Tensor calculated?
The Riemann Curvature Tensor is calculated using the Christoffel symbols, which are derived from the metric tensor. The Christoffel symbols are then used to calculate the components of the Riemann Curvature Tensor using a specific formula.
3. What is the significance of the Riemann Curvature Tensor in 2D?
The Riemann Curvature Tensor is significant because it provides a way to measure the curvature of a two-dimensional space. It is a fundamental concept in differential geometry and is used in many areas of physics, including general relativity.
4. How does the Riemann Curvature Tensor relate to the Gaussian curvature?
The Riemann Curvature Tensor and the Gaussian curvature are closely related. In 2D, the Gaussian curvature is equal to the product of the two principal curvatures, which are determined by the eigenvalues of the Riemann Curvature Tensor.
5. Can the Riemann Curvature Tensor be visualized in 2D?
Yes, the Riemann Curvature Tensor can be visualized in 2D using a curvature plot. This plot shows how the curvature changes at each point in the space. It can also be visualized using a surface plot, where the curvature is represented by the height of the surface at each point.
