MHB Riemann Integration ... Existence Result .... Browder, Theorem 5.12 ....
Math Amateur
MHB
I am reading Andrew Browder's book: "Mathematical Analysis: An Introduction" ... ...
I am currently reading Chapter 5: The Riemann Integral and am currently focused on Section 5.2 Existence Results ... ...
I need some help in understanding the proof of Theorem 5.12 ...Theorem 5.12 and its proof read as follows:
View attachment 9501In the above proof by Andrew Browder we read the following:
" ... ... [For instance, one can choose a positive integer $$n$$ such that $$n \gt [f(b) - f(a) + 1](b - a) / \epsilon$$ ... ... "My question is as follows:
Why does Browder have $$+1$$ in the expression $$[f(b) - f(a) + 1](b - a) / \epsilon$$ ... ... ?Surely $$[f(b) - f(a)](b - a) / \epsilon$$ will do fine ... since ...
$$\mu ( \pi ) = (b - a)/ n$$
and so
$$\mu ( \pi ) [f(b) - f(a)] = [f(b) - f(a)] (b - a)/ n \lt \epsilon$$ ...
... so we only need ...
$$n \gt [f(b) - f(a)](b - a) / \epsilon$$
Hope someone can help ...
Peter
The +1 in the expression [f(b) - f(a) + 1](b - a) / \epsilon is used to ensure that the inequality holds in all cases. If we only use [f(b) - f(a)](b - a) / \epsilon, we can only guarantee that the inequality will hold if f(b) ≥ f(a). However, if f(b) < f(a) then we can't guarantee that the inequality will hold. The +1 ensures that the inequality holds for any value of f(b) and f(a).
Hi Peter,
I can definitely understand your confusion with the +1 in the expression. Here's my understanding of it:
In this proof, Browder is trying to show that for any given \epsilon \gt 0, there exists a partition \pi of [a,b] such that \mu(\pi)[f(b) - f(a)] \lt \epsilon. In order to do this, he chooses a positive integer n such that n \gt [f(b) - f(a) + 1](b - a) / \epsilon.
The reason for the +1 is because Browder wants to make sure that the value of n is large enough to guarantee that \mu(\pi)[f(b) - f(a)] is less than \epsilon. By adding 1 to [f(b) - f(a)], he is ensuring that n is large enough to cover any potential "gaps" in the interval [f(b) - f(a), \epsilon].
In other words, if we only have n \gt [f(b) - f(a)](b - a) / \epsilon, there is a possibility that the value of n may not be large enough to cover all possible values within the interval [f(b) - f(a), \epsilon]. By adding 1, we are ensuring that n is large enough to cover all possible values within this interval.
I hope this helps clarify the use of +1 in the expression. Let me know if you have any further questions.
A sphere as topological manifold can be defined by gluing together the boundary of two disk. Basically one starts assigning each disk the subspace topology from ##\mathbb R^2## and then taking the quotient topology obtained by gluing their boundaries. Starting from the above definition of 2-sphere as topological manifold, shows that it is homeomorphic to the "embedded" sphere understood as subset of ##\mathbb R^3## in the subspace topology.
