Rifleman standing between two cliffs hears two echos from a single shot
  • Thread starter Thread starter GforOevOerD
A rifleman standing between two cliffs hears two echoes after shooting a rifle, with the first echo occurring 4 seconds after the shot and the second echo 2 seconds later. The closer cliff is 700 meters away, and the discussion revolves around calculating the distance between the two cliffs while accounting for the rifleman's movement towards the closer cliff. Participants suggest starting with the stationary case to establish a baseline, then modifying the calculations to include the rifleman's running speed. The conversation emphasizes understanding how the distance sound travels is affected by the rifleman's movement and the time intervals between echoes. The goal is to determine the correct distance between the cliffs based on these parameters.
GforOevOerD
Summary:: Hello.There is a rifleman standing between two cliffs with vertical walls, and the distance of closer cliff is 700 meters. If he shoots and run toward the closer cliff ( 700 meters ) and hears the first echo after 4 (s) and second echo after 2 (s) of the first echo, what is the distance of two cliffs?
A : 1700
B : 1740
C : 1750
D : 1690
I can solve when the man is just standing, but not moving. However, I don't know what to do when he is running. I'd be so grateful if you could help me.
Welcome to PF :smile:
Please show us your solution for when the Rifleman is stationary. Then we can discuss which variable needs to be modified when he is moving. Thanks.
In the first 4s, how far does he run? How much less has the sound traveled when he hears that first echo? (just let his running speed = v for now). How does that change what you did for the case where he is stationary?
After 6s, when he hears the 2nd echo, how far has he run? How does that adjust your working from the stationary case?(There may be a better way, I had to assume a speed for sound and it turns out he's running quite fast...)
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
