MHB Right Angled Triangle: Find $\sin(\theta)$
  • Thread starter Thread starter kaliprasad
    Triangle
In a right-angled triangle with sides \(a, b, c\) and the smallest angle \(\theta\), it is established that if the reciprocals \(\frac{1}{a}, \frac{1}{b}, \frac{1}{c}\) also form a right-angled triangle, then \(\sin(\theta)\) can be expressed as \(\frac{\sqrt{5} - 1}{2}\). This relationship highlights a unique property of the triangle's angles and side lengths. The derivation involves understanding the geometric implications of both triangles. The discussion emphasizes the mathematical connection between the angles and the ratios of the sides in right-angled triangles.
kaliprasad
MHB
Let $a,b,c$ be the sides of a right angled triangle. Let $\theta$ be the smallest angle of this triangle.
If $\dfrac{1}{a}, \dfrac{1}{b}, \dfrac{1}{c}$ are also the sides of a right angled triangle then show that $\sin(\theta) = \dfrac{\sqrt{5} - 1}{2}$
Mathematics news on Phys.org
Interesting question. :)
Without loss of generality let us take $c$ to be the length of the hypotenuse and $b$ to be the length of the smallest side. That is, \(c>a>b\). Therefore \(\frac{1}{c}<\frac{1}{a}<\frac{1}{b}\). That is the \(\frac{1}{b}\) is the length of the hypotenuse of the smaller triangle. Using the Pythagorean theorem for both triangles we get,
\[a^2+b^2=c^2\]
and
\[\left(\frac{1}{a}\right)^2+\left(\frac{1}{c}\right)^2=\left(\frac{1}{b}\right)^2\]
From these two equations we can get,
\[bc=a^2\]
And hence,
\[\sin\theta=\frac{b}{c}=\frac{a^2}{c^2}=cos^2\theta=1-\sin^2\theta\]
\[\therefore \sin^2\theta+\sin\theta-1=0\Rightarrow \sin\theta=\frac{\sqrt{5}-1}{2}\]
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
