MHB Right-Angled Triangle Inequality
In a right triangle with sides a, b, and hypotenuse c, it is established that the inequality $$\frac{(c − a)(c − b)}{(c + a)(c + b)}\le 17 − 12\sqrt{2}$$ holds true. The discussion involves proving this inequality through various mathematical approaches. Participants explore different methods of manipulation and substitution to validate the inequality. The conversation emphasizes the importance of understanding the properties of right triangles in relation to the derived expression. Ultimately, the proof reinforces fundamental concepts in triangle inequalities.
anemone
MHB
POTW Director
Show that if $a,\,b$ and $c$ are the lengths of the sides of a right triangle with hypotenuse $c$, then
Mathematics news on Phys.org
From law of symmetry we shall have this shall have extremum at a = b giving $c= \sqrt{2}a$ and
$LHS = \frac{(c − a)(c − b)}{(c + a)(c + b)} = \frac{(\sqrt{2}-1)^2}{(\sqrt{2}+1)^2}= (\sqrt{2}-1)^4 = 17 - 12\sqrt{2}$
taking another point (a = 0, c=b) we get LHS = 0
hence $\frac{(c − a)(c − b)}{(c + a)(c + b)}\le 17 − 12\sqrt{2}$
$a,b,\,\, and\,, c$ are the lengths of the sides of a right triangle
$a$ cannot be $"0"$
and more :
$c$ is hypotenuse ,we have $b<c$
$a$ cannot be $"0"$
and more :
What you are telling is right. I took the limiting case
My solution:
We have $c^2−a^2=b^2 \implies c−a=\dfrac{b^2}{c+a}$.
By the similar token, we also have $c−b=\dfrac{a^2}{c+b}$, if we're going to replace these two into the original LHS of the inequality, we get:$$\begin{align*}\frac{(c − a)(c − b)}{(c + a)(c + b)}&=\frac{(b^2)(a^2)}{(c + a)^2(c + b)^2}\\&=\left(\frac{ab}{(c + a)(c + b)}\right)^2\\&=\left(\frac{ab}{c^2+c(a+b)+ab}\right)^2\\&=\left(\frac{1}{\dfrac{c^2}{ab}+\dfrac{c(a+b)}{ab}+1}\right)^2\\&\le \left(\frac{1}{\dfrac{c^2}{ab}+\dfrac{c(2\sqrt{ab})}{ab}+1}\right)^2\,\,\text{(by the AM-GM inequality)}\\& = \left(\frac{1}{\left(\dfrac{c}{\sqrt{ab}}\right)^2+\dfrac{2c}{\sqrt{ab}}+1}\right)^2\text{but from $c^2=a^2+b^2\ge 2ab$, we get $\dfrac{c}{\sqrt{ab}}\ge \sqrt{2}$}\\& \le \left(\frac{1}{\left(\sqrt{2}\right)^2+2\sqrt{2}+1}\right)^2\\&= \left(3-2\sqrt{2}\right)^2\\&= 17-12\sqrt{2}\,\,\,\text{Q.E.D.}\end{align*}$$
Equality occurs when $a=b$.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
