Rigid Body on Frictionless Surface
In summary, the conversation discussed the possibility of tipping over a block on a frictionless surface, with the conclusion that it is possible if the applied force exceeds a certain threshold. The concept of moments and torque were also explained, along with the use of a pulley and thread to apply the force. The idea of "rocking" the block was also mentioned as a possible technique. Ultimately, the correct choice of axis of rotation at the center of mass was determined for the most accurate analysis.
bpmeyer46
Hey all,
Say you have a slab sitting vertically(like a door) at rest on a frictionless surface. If you push with a horizontal force somewhere near the top(as long as it is above the center of mass), would the slab rotate(tip over)?
My friend and I were originally thinking of how much horizontal force you would have to push a block with to tip it over on a surface with friction. This turned into a question of whether or not you actually could tip a block if it was on a frictionless surface. We both said no, but then we thought about if you replaced the block with a door and it made us think twice.
Right now we are leaning towards the object rotating, or tipping over, but we aren't completely sure and would like some more input on the problem. Does it depend on the weight of the object? Does it depend on how much force you apply? Does it depend on where you apply the force?
Also, we are saying the body is rigid. We have tried to break it down into a simpler model, with no avail. Hopefully you guys can help.
Thanks
It's a question of moments. Suppose a force F is applied at height h to a rectangular block of mass m, width 2w (in the direction of the applied force) . Taking moments about the potential tipping point, it will tip if Fh > mgw. The reason it can be counterintuitive is that pushing with a steady force when there's no friction is hard to do. The block will accelerate rapidly, and it's hard for the force to keep up. Best way may be to think of applying the force by attaching a horizontal thread that runs over a pulley to another mass suspended vertically.
Ah that makes a lot of sense. Also the thread idea is great. I think we just put too much thought into the problem.
Thanks
Suppose that the block has width w, height h, mass m and is in gravitational field g.
You apply force f at the top. Your applied torque is f * h.
Let's say you're pushing to the left. The block starts tipping around the lower left corner. The force of gravity is m * g and its torque is exerted over a moment arm of w/2.
As long as the force you apply is less than m*g*w/2 / h then you will fail to accomplish anything -- the block will resist tipping.
If the force you apply is greater than this, the block will begin tipping. Keep it up until the block is at the balance point with the top right corner directly above the bottom left corner and it will continue on its own.
Note that you can get away with less force using a technique known as "rocking". This is easier if there is friction, but is also possible without it. The resonant frequency is increased [by a factor of 2?] in the frictionless case since you are effectively rotating around the center of mass rather than around the frictionally anchored base.
Edit
In the frictionless case, the correct choice of axis of rotation is at the center of mass.
That means that your moment arm is only f*h/2 and the required force is f = m*g*w.
[It is possible to do the analysis with the axis of rotation chosen at the lower left hand corner, but then the linear motion of the block contributes to angular momentum and must be accounted for in the comparison of torques]
for any input!
I can provide some insight into this problem. First of all, on a frictionless surface, there would be no opposing force to counteract the horizontal force applied to the object. This means that the object would indeed rotate or tip over if a sufficient amount of force is applied above its center of mass. This would hold true for any object, regardless of its weight, as long as the force is applied above its center of mass.
However, the exact amount of force required to tip the object over would depend on its weight, as well as the distance between the applied force and the center of mass. This can be calculated using principles of rotational mechanics, taking into account the object's moment of inertia.
It is also important to note that the object must be rigid in order for this scenario to play out as described. If the object was not rigid, the force applied would cause it to deform and potentially slide instead of rotating.
I hope this helps clarify the situation and provides some more information to consider in your analysis. Good luck with your problem-solving!
Related to Rigid Body on Frictionless Surface
1. What is a rigid body on a frictionless surface?
A rigid body on a frictionless surface is a common physics problem in which a solid object is placed on a surface with no friction. This means that there is no resistance to the movement of the object, allowing it to move freely without any external forces acting on it.
2. What are the assumptions made when studying a rigid body on a frictionless surface?
The main assumptions made when studying a rigid body on a frictionless surface are that the object is perfectly rigid and that there is no friction between the object and the surface it is placed on. Additionally, there are no external forces acting on the object, such as gravity or air resistance.
3. What is the significance of studying a rigid body on a frictionless surface?
Studying a rigid body on a frictionless surface allows scientists to understand the fundamental principles of mechanics, such as Newton's Laws of Motion, without the complicating factor of friction. This simplification allows for easier analysis and calculations, making it a useful tool for understanding more complex systems.
4. How does the motion of a rigid body on a frictionless surface differ from that of a real-life object?
In real-life scenarios, it is nearly impossible to have a completely frictionless surface. This means that the motion of a real-life object will be affected by friction, causing it to slow down or stop over time. Additionally, real-life objects are not perfectly rigid, so they can bend or deform under certain forces.
5. Can a rigid body on a frictionless surface ever come to a complete stop?
No, a rigid body on a frictionless surface will continue to move with constant velocity unless acted upon by an external force. This is due to the absence of friction, which would normally cause the object to eventually come to a stop. However, in a frictionless environment, the object will continue to move indefinitely.
  • Mechanics
