MHB Ring of integer p-adic numbers.
The ring of integer p-adic numbers, denoted as $\mathbb{Z}_p$, is established as a principal ideal domain (PID), meaning all its ideals are principal. The embedding function $\epsilon_p$ maps integers from $\mathbb{Z}$ into $\mathbb{Z}_p$, confirming that $\mathbb{Z}$ is a subset of $\mathbb{Z}_p$. The units in $\mathbb{Z}_p$ are characterized as those elements not divisible by the prime p, represented by the series where the leading coefficient is non-zero. Each non-zero element in $\mathbb{Z}_p$ can be uniquely expressed in the form $x = p^m u$, linking the valuation to the structure of the ideals. The unique maximal ideal of $\mathbb{Z}_p$ is $p\mathbb{Z}_p$, reinforcing the principal nature of its ideals.
evinda
MHB
Hey! (Wave)
Let the ring of the integer $p$-adic numbers $\mathbb{Z}_p$.
Could you explain me the following sentences? (Worried)
  1. It is a principal ideal domain.
  2. The function $\epsilon_p: \mathbb{Z} \to \mathbb{Z}_p$ is an embedding.
    (So, $\mathbb{Z}$ is considered $\subseteq \mathbb{Z}_p$)
  3. The units of the ring $\mathbb{Z}_p$:
    $$\mathbb{Z}^*=\mathbb{Z} \setminus p \mathbb{Z}$$
    so the units are
    $$= \{ \sum_{n=0}^{\infty} a_n p^n | a_0 \neq 0\}$$
  4. Each element $x$ of $\mathbb{Z}_p \setminus \{ 0 \}$ has a unique expression of the form $x=p^m u | m \in \mathbb{N}_0$
  5. $\mathbb{Z}_p$ has exactly these ideals:
    $$0, p^n \mathbb{Z}_p (n \in \mathbb{N}_0)$$
    Furthermore, $\cap_{n \in \mathbb{N}_0} p^n \mathbb{Z}_0=\{0\}$ and $\frac{\mathbb{Z}_p}{p^n \mathbb{Z}_p} \cong \frac{\mathbb{Z}}{p^n \mathbb{Z}}$
    Last but not least, the unique maximal ideal of $\mathbb{Z}_p$ is $p \mathbb{Z}_p$.
Mathematics news on Phys.org
  1. Let $\mathfrak{p}$ be a nonzero ideal of $\mathbf{Z}_p$, and a nonzero $x \in \mathfrak{p}$ such that $\nu_p(x) < \infty$ is the smallest order in all of $\mathfrak{p}$. $x = p^{\nu_p(x)} a$ by definition of the valuation, implying $p^{\nu_p(x)} = a^{-1} x$. As the LHS is in $\mathfrak{p}$, $p^{\nu_p(x)} \in \mathfrak{p}$, indicating that $\left \langle p^{\nu_p(x)}\right \rangle$ is sitting inside $\mathfrak{p}$. But then any integer $y$ can be written as $y = p^{\nu_p(y)} a$, and assuming $\nu_p(y) \geq \nu_p(x)$, $y = p^{\nu_p(x)} \cdot (p^{\nu_p(y) - \nu_p(x)} a) \in \left \langle p^{\nu_p(x)} \right \rangle$. Hence $\mathfrak{p}$ sits inside $\left \langle p^{\nu_p(x)} \right \rangle$ in turn, but this is only possible if $\mathfrak{p} = \left \langle p^{\nu_p(x)} \right \rangle = p^{\nu_p(x)} \Bbb Z$, and we prove the first part of $\#5$ more generally. This implies that all of the ideals are principal, hence $\mathbf{Z}_p$ is a PID.
  2. What is your $\epsilon_p$? It's obvious that $\mathbf{Z}_p$ has a copy of $\mathbb{Z}$ sitting inside : take the infinite-tuple $(x_1, x_2, x_3, \cdots)$ where $x_i = n \pmod{p^i}$, $n$ being your given integer.
  3. Left as an exercise.
  4. This is straightforward from $\#4$. $x$ have the $p$-adic representation $$x = \sum_{k \geq \nu_p(x)} a_k p^k = p^{\nu_p(x)} \sum_{k \geq 0} a_k p^k$$ The sum there is a unit from exercise $\#4$, so you have the desired.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
