Risk of Legionella when storing water?
  • Thread starter Thread starter TSN79
    Water
Heating water to 65°C effectively kills Legionella, a bacterium that poses health risks, particularly through aerosolization in systems like air conditioning. Once the water is heated and stored in a clean, closed container, it is unlikely to become recontaminated unless exposed to a new source of the bacteria. If kept cool, ideally below 20°C, the water can be stored safely for a week without risk. Concerns about Legionella have increased due to past outbreaks, leading to heightened awareness and precautionary measures, even if the initial heating process is sufficient for disinfection.
TSN79
Cold water is heated to 65°C so that Legionella is killed. If the water is then stored in a tank and allowed to cool down to room temperature, can it "magically" reappear or can the water be stored a while (maybe a week) without risk?
Biology news on Phys.org
60-65C is the minimal sufficient temperature range to kill Legionella. Why do you feel you needed to treat this water in the first place? The biggest danger with contaminated water is that the microbe can be spread by aerosolization, typically by large central air conditioning systems. The water will not likely become recontaminated unless exposed to a potential source, which is why I ask the question.
Otherwise, if the water is free of the microbe and stored in a clean closed container in a cool place (at least under 20C, but the cooler the better), there should be no problem.
Personally I don't, but ever since there was an outbreak of Legionnaires' disease (although it was traced back to a scrubber which isn't really a justifiable comparison imo) there's a bit of hysteria going around amongst people. I know that questions regarding it will come once the installation is done so I just thought I'd check if the initial heating would take care of it.
I've been reading a bunch of articles in this month's Scientific American on Alzheimer's and ran across this article in a web feed that I subscribe to. The SA articles that I've read so far have touched on issues with the blood-brain barrier but this appears to be a novel approach to the problem - fix the exit ramp and the brain clears out the plaques. https://www.sciencealert.com/new-alzheimers-treatment-clears-plaques-from-brains-of-mice-within-hours The original paper: Rapid amyloid-β...
