Robotic Table Tennis Player: Selecting Motors for High Response
For a robotic table tennis player, high response and medium torque motors are essential for effective ball tracking and shot execution. Brushless DC servo motors are recommended due to their fast response times and high torque capabilities. It's crucial to consider motors that offer precision and accuracy for accurate racket movements. Variable speed control can enhance the robot's ability to perform different types of shots. Thorough research and testing of motor options will help identify the best fit for the project.
l094400
Hi i want to work on robotic table tennis player. So i am confuse that which kind of motors should i use. I need high response motors.
Just off the top of my head, and without much knowledge of your application, it sounds like you want to use a brushless DC servo motor.
Ok. I try to explain you.
1. We need to choose final year project For which i have to submit my report on it
2. The project we decided is robotic table tennis player
3. There will be camera and it will detect the motion of ball
4. According to this motion we need to move our rackets
So my question is What kind of motors do we need for Fast response and medium torque?
Regards
Shoaib Akhtar
I maintain my answer from my previous post. Look up some brushless dc servo motors. Manufacturers websites typically have all the information you need, including peak torque and a torque vs. speed curve.
I would suggest considering motors that have high torque and fast response times. This will allow the robotic table tennis player to quickly react to the movements of the ball and return shots with precision. Additionally, motors with high precision and accuracy will also be important in order to accurately control the movements of the robotic player. It may also be beneficial to consider motors with variable speed control, as this can provide the flexibility needed for different types of shots in table tennis. Ultimately, it is important to carefully research and test different motor options to find the best fit for your specific project and goals.
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
Thread 'Electromagnet magnetic field issue'
Hi Guys We are a bunch a mechanical engineers trying to build a simple electromagnet. Our design is based on a very similar magnet. However, our version is about 10 times less magnetic and we are wondering why. Our coil has exactly same length, same number of layers and turns. What is possibly wrong? PIN and bracket are made of iron and are in electrical contact, exactly like the reference design. Any help will be appreciated. Thanks. edit: even same wire diameter and coil was wounded by a...
