Rocket Out of Fuel: Time and Altitude
  • Thread starter Thread starter afa
    Fuel Rocket
The discussion revolves around a physics problem involving a rocket that accelerates upward at 4.0 m/s² until it runs out of fuel at 1500 meters. The initial calculations indicate that the rocket reaches a velocity of 110 m/s when it exhausts its fuel. Participants are seeking assistance on determining the time taken to reach this altitude, the maximum altitude achieved, the total time in the air, and the velocity upon impact with the Earth. There is confusion regarding the application of the equations of motion and the need for clarity on units. The conversation highlights the importance of correctly applying kinematic equations to solve the problem effectively.
afa
A rocket rises vertically, from rest, with an acceleration of 4.0 until it runs out of fuel at an altitude of 1500 . After this point, its acceleration is that of gravity, downward.
How long does it take to reach this point?
What maximum altitude does the rocket reach?
How much time (total) does it take to reach maximum altitude?
With what velocity does the rocket strike the Earth
How long (total) is it in the air?
x=x+vt+.5at^2
I found velocity when it runs out of fuel to be 110m/s don't know how to get the rest??
We need more units! I'm guessing acceleration of 4.0m/s and an altitude of 1500 meters?
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
