timmdeeg
- 342
Thanks for explaining, I'm sorry about this misunderstanding though. According to my question herePeterDonis said:The usual way is, as I have said, to assume one. Typical ones used in cosmology are:
Matter: ##p = 0## (i.e., no pressure). This would apply to both ordinary visible matter and dark matter.
Radiation (and relativistic matter): ##p = \frac{1}{3} \rho## (where ##\rho## is the energy density). This is negligible now since there is no significant relativistic matter in the universe, the main radiation energy density in the present universe is the CMBR, and its energy density is several orders of magnitude smaller than that of matter. But in the early universe this equation of state is very important.
Dark energy: ##p = - \rho##. This is the dominant component of the present universe, and the pressure being negative corresponds to accelerating expansion. (More precisely, ##p < - \frac{1}{3} \rho## corresponds to accelerating expansion.) A similar equation of state is used in inflationary cosmology, with a much larger ##\rho## and therefore a much faster acceleration of the expansion.
All of these equations of state are really special cases of the general perfect fluid equation of state, whose general form is ##p = w \rho##, where ##w## can take various values. As you can see, "matter" corresponds to ##w = 0##, "radiation" corresponds to ##w = 1/3##, and "dark energy" corresponds to ##w = - 1##.
I was erroneously assuming that you mentioned the "equation of state" in the context of the rod (describing the "internal forces") and was astonished about that. It is clear that the cosmological fluid doesn't exert pressure.timmdeeg said:Yes, the released particles can't exert pressure, I didn't want to say that. Instead I was thinking that the directions of their motion indicate the creation of pressure in the rod (not tension as discussed before concerning the radial free infall of the rod) with the maximum in its geometrical center, because in this case the situation is symmetric per se.
Unfortunately "the pressure is put in by hand in the equation of state" doesn't say much to me. Could one simply understand the pressure being due to the summarized "weight" of the parts of the rod?
So, assuming Born rigidity would it be possible to do a rough calculation (or at least a rough estimate) to find out on which point of the rod the internal forces are balanced? The answer to this question seems clear in FRW- but not in Schwarzschild-spacetime. Are these forces a function of the speed of the rod relative to a freely falling particles measured locally? I think this speed increases from zero if one moves along the rod starting at the balanced point and is probably greater at the bottom than at the top (in contrast to the FRW case). It seems however you disagree that such considerations will guide the intuition (of PAllen and myself) in the right direction. In short, is it hopeless to come to an definite conclusion without to "work through the math"?PeterDonis said:That is one way of obtaining a model, but it's not always possible; some states of motion of extended objects are not compatible with Born rigid motion at all. The gory details are in something called the Herglotz-Noether theorem.
Also, specifying Born rigid motion doesn't tell you how that motion is physically produced; it doesn't tell you the internal forces between the parts, it just tells you that, whatever those forces are, they are capable of producing Born rigid motion. So Born rigidity by itself doesn't give you things like the pressure and stress in the object.
By the way, here
http://users.ugent.be/~nvdbergh/workshop/info/Filipe Costa.pdf, slide 2
Costa mentions
"- no real (i.e., extended) bodies move along geodesics (only idealized point monopole) particles
- in general, no point in the bodies moves along a geodesic (not even the center of mass)"
But this might not regard the case we are discussing here, because you mentioned already "This is true, but the effect is negligible in weak fields".
