Automotive Rolling resistance coefficient on sand
Calculating the rolling resistance coefficient on sand for a 37/12.5 R37 tire involves several factors, including tire pressure, wheel loading, and the type of sand. Lowering tire pressure can increase the contact patch area, reducing rolling resistance, but may risk tire damage on rocky terrain. All-wheel drive can help prevent the vehicle from bogging down in sand. The specific characteristics of the sand, such as moisture content and stability angle, are crucial for accurate calculations. Without knowing these details, a rough estimate of rolling resistance could be assumed as 1.00 while the vehicle is in motion.
jeromedynamics
TL;DR Summary
Rolling resistance coefficient on sand tyre 37/12.5 R37
Hello I,d like to find or to calculate Rolling resistance coefficient on sand tyre 37/12.5 R37. Thanks for your help
Welcome to PF.
There are several factors here.
Why do you need to calculate rolling resistance?
What range of tyre pressure, wheel loading, driven or lazy axle?
What type of sand, stability angle, moisture content?
Vehicle velocity?
Likes jeromedynamics
Interesting to see that resistance coefficient increases with tire pressure on sand.
Thanks for your reply
Baluncore said:
Welcome to PF.
=> to have an estimation about autonomy of a vehicle
The 4 wheels of a 4X4
=>I don't know = The vehicle will be used in the South America desert
Vehicle velocity?
=>95 km/h (max 180 km/h)
Have a nice day
Try not to edit inside quotes. It makes it difficult to reply to the points.
Autonomy or economy? Travelling at speed over sand will be very inefficient.
All-wheel-drive will reduce rolling resistance because it will help prevent the tyres digging holes, bogging down, and the vehicle sinking.
To lower rolling resistance over sand, maximise the wheel diameter and tyre width, (but you have fixed those parameters as 37/12.5 R37), so you must use a low tyre pressure to increase the area of the contact patch. The tyres will be destroyed if you then travel fast over rocky ground without increasing the pressure. Reduce the total weight of the vehicle. Improve the suspension to reduce ground impact.
You will need to investigate the sand. Windblown sand will be a problem.
To experiment, get some rounded bedding sand that flows, to compare with some sharp sand used for mortar. Test the slope before they flow when dry, then when wet.
Vehicle velocity?
There are dynamic effects. At high speed you may float over the sand before it has time to flow, but if you slow down, the sand will move and rolling resistance may be greatly increased. The tuning of the suspension will be very important.
If you cannot characterise the sand, you will be unable to estimate rolling resistance, and so must assume it to be 1.00 while the vehicle still moving, before it bogs.
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
