Rolling Sphere On Incline
The discussion centers on calculating the angular velocity of a solid sphere rolling down an incline. The user derived the equation mgh=1/2MR^2ω^2+1/2(2/5MR^2)ω^2 but obtained incorrect omega values of 111.09 and 114.09. Participants pointed out the necessity of including units in calculations and suggested verifying the height (h) used in the equations. They recommended drawing a diagram to clarify the correct height measurement. The conversation emphasizes the importance of accuracy in both calculations and understanding the physical setup.
Randomized10
An 8.6-cm-diameter, 320 g solid sphere is released from rest at the top of a 1.7-m-long, 17 degree incline. It rolls, without slipping, to the bottom. What is the angular velocity of the sphere at the bottom?
I=2/5MR^2
LKE=1/2Mv^2
RKE=1/2Iomega^2
mgh=LKE+RKE
I did some algebra and got the final equation mgh=1/2MR^2omega^2+1/2(2/5MR^2)omega^2, then plugged in the numbers and got an omega value of 111.09. Using 1.7 as h instead of cos(17)*1.7=1.63 I got 114.09. Both answers were wrong. Am I missing something, or did I just screw up the math?
Randomized10 said:
Homework Statement: An 8.6-cm-diameter, 320 g solid sphere is released from rest at the top of a 1.7-m-long, 17 degree incline. It rolls, without slipping, to the bottom. What is the angular velocity of the sphere at the bottom?
Relevant Equations: I=2/5MR^2
LKE=1/2Mv^2
RKE=1/2Iomega^2
mgh=LKE+RKE
Numbers without units are meaningless. Please repost with units this time and when you do, show more details.
Also, why do you think h = 1.7 or even cos(17)*1.7 ? Draw a diagram and see what h is.
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
