Rolling Steel Ball Acceleration Questions
To determine how long it takes for the steel ball to stop on the second slope, first calculate the acceleration on the first slope using the formula v = at, where the final velocity (v) is 5.0 m/s and the time (t) is 2.5 s. This gives an acceleration of 2.0 m/s² on the first slope. The acceleration on the second slope is half of this, resulting in 1.0 m/s². Using the same formula, the time to stop on the second slope can be calculated as 5.0 seconds. Thus, it takes the ball 5.0 seconds to come to a stop on the second slope.
j1249
a steel ball, starting from rest rolls down one slope and up another. it takes 2.5s to reach the bottom of the first slope, at which point its speed is 5.0 m/s. if the magnitutde of the acceleration on the second slope is exactly one-half that on the first slope, how long will it take for the ball to come to a stop on the second slope?
The key is to get a value of the acceleration on the first slope. You should be able to get that by using the values given in
v=at
where v is the final velocity, a is the acceleration and t is the time.
alright great thanks alot! :)
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
