MHB Roots of equation and probability
  • Thread starter Thread starter anemone
    Probability Roots
anemone
MHB
POTW Director
Let $v$ and $w$ be distinct, randomly chosen roots of the equation $z^{1997}-1=0$. Find the probability that $\sqrt{2+\sqrt{3}}\le |v+w|$.
Mathematics news on Phys.org
We are given $1997$ equidistant points on the unit circle in the complex plane each of which is a solution to the equation $z^{1997}-1 = 0$. The angular spacing between neighbouring solutions is:
\[\Delta \theta = \frac{2\pi}{1997} \approx 0,0031463\]
WLOG we can let $u = 1 +i0$, and choose $w$ arbitrarily among the 1996 other possibilities. The angle, $\theta$, between $u$ and $w$, determines the absolute value of the sum $u + w$:
\[|u+w| = 2 \cos \frac{\theta }{2} \geq \sqrt{2+\sqrt{3}}\]
The low limit can be expressed as a cosine:
\[\sqrt{2+\sqrt{3}} = \sqrt{2}\sqrt{1+\frac{\sqrt{3}}{2}} = \sqrt{2}\sqrt{\cos 0 + \cos \frac{\pi}{6}} = \sqrt{2}\sqrt{2 \cos^2 \frac{\pi}{12}} = 2 \cos \frac{\pi}{12}\]
Hence, we have the condition: $\cos \frac{\theta}{2} \geq \cos \frac{\pi}{12}$ or $- \frac{\pi}{6}\leq \theta\leq \frac{\pi}{6}$
Thus, having chosen $u$, the $w$’s which fulfill the inequality may be chosen up to a max. angular distance of $\frac{\pi}{6}$ from $u$.
There are $\left \lfloor \frac{\pi}{6 \Delta \theta } \right \rfloor = 166$ solutions on both sides of $u$, which fulfill the inequality.
If $w$ is picked out at random, we get the probability
\[\frac{2\cdot 166}{1996} = \frac{83}{499} \approx 16,63 \%.\]
This result differs slightly from the fraction: $\frac{1}{6} = 16,666.. \%$, which would be obtained in the limit: $\Delta \theta \approx 0$ ($N \rightarrow \infty$).
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
