Rotary or centrifugal jet spinning (nanofiber)
In summary, a research student is working on rotary jet spinning and has noticed that the formed nanofibers are not properly attached to the collector, resembling a spider web. This could be due to improper spinning speed, incorrect viscosity of the spinning solution, or the wrong type of collector being used. Using a rotating collector is recommended for proper collection.
nashikin58
Hi, I am a research student, working on rotary jet spinning. while spinning, nanofibers are formed but it's not attached properly to the collector. It became like a spider web. You guys have any idea why it became like that?
It could be due to a few things. First, it could be due to improper spinning speed causing the nanofibers to form too quickly and not adhere properly to the collector. Second, it could be due to an incorrect viscosity of the spinning solution, which would cause the nanofibers to not form correctly. Finally, it could be due to the wrong type of collector used. If you are using a static collector, the nanofibers may not adhere properly. It's best to use a rotating collector to ensure proper collection.
FAQ: Rotary or centrifugal jet spinning (nanofiber)
What is rotary or centrifugal jet spinning?
Rotary or centrifugal jet spinning is a technique used to produce nanofibers. It involves the use of a high-speed rotating disc or drum to create a centrifugal force, which extrudes a polymer solution through a small nozzle to form continuous nanofibers.
What are the advantages of rotary or centrifugal jet spinning?
Some advantages of rotary or centrifugal jet spinning include the ability to produce continuous nanofibers at high production rates, as well as the potential to produce a wide range of nanofiber diameters. It also allows for the production of nanofibers from a variety of polymers and the incorporation of functional materials.
What are the applications of rotary or centrifugal jet spinning?
Rotary or centrifugal jet spinning has a wide range of applications in various fields such as biomedicine, energy, and textiles. It can be used to produce nanofibers for tissue engineering, drug delivery, filtration, and reinforcement in composites, among others.
What are the limitations of rotary or centrifugal jet spinning?
One limitation of rotary or centrifugal jet spinning is the inability to control the alignment of nanofibers, leading to a random orientation. It also requires a high-speed rotation, which can be challenging to maintain over long periods. Additionally, the process may result in some defects in the nanofibers.
How does rotary or centrifugal jet spinning compare to other nanofiber production techniques?
Compared to other techniques such as electrospinning or melt spinning, rotary or centrifugal jet spinning offers higher production rates and the ability to produce a wider range of nanofiber diameters. However, it may not be suitable for producing highly aligned nanofibers or for certain types of polymers that are not compatible with the process.
