Rotational motion: Find angular displacement when rotation speed is changing
In summary, the problem involves finding the angle of rotation of a wheel given its initial and final angular speeds and the time it took to change speeds. The incorrect attempt at a solution used an equation for angular velocity instead of a relevant equation for angular displacement. The correct approach would involve using equations for angular motion and considering the angular acceleration.
mememe1245
A torque acts on a wheel rotating at 19.8 rad/s and increases its angular speed to 23.5 rad/s in 11.2 s. Find the angle through which the wheel turns during this time.
omega = theta/time
23.5 - 19.8/11.2 = .33rad/s/s --- this is wrong.
Your thread title is non-descriptive of the thread content. I will change it this time.
Clearly the problem involves a change in rotation speed, so an angular acceleration is involved. You haven't presented any Relevant Equations involving acceleration.
Can you explain your attempt at solution? Use symbols rather than numbers.
omega = theta/time
The problem clearly states, "Find the angle ..." Is 0.33 rad/s/s how you measure an angle?
Review your equations for angular motion. There should be one which gives you the angular displacement if you know: the time, the angular velocity, and the angular acceleration.
You found out the angular acceleration...NOT the angle present.
Try using proper required equations to find out the angle displaced
(Hint:- kinematic equations and equations for circular motions are pretty much the same
To find the angular displacement, we need to use the formula:
theta = omega*t + (1/2)*alpha*t^2
Where:
theta = angular displacement
omega = initial angular velocity
alpha = angular acceleration
t = time
In this problem, we are given:
omega = 19.8 rad/s (initial angular velocity)
alpha = torque (unknown)
t = 11.2 s (time)
To find alpha, we can use the formula:
alpha = torque/mass*radius
Where:
torque = torque acting on the wheel
mass = mass of the wheel
radius = radius of the wheel
Since we are not given the mass or radius of the wheel, we cannot solve for alpha. However, we can still calculate the angular displacement by using the initial and final angular velocities given in the problem.
Substituting the values into the formula, we get:
theta = (23.5 rad/s * 11.2 s) + (1/2)(alpha)(11.2 s)^2
= 263.2 rad + (1/2)(alpha)(125.44 s^2)
Since we do not have the value for alpha, we cannot solve for the exact angular displacement. However, we can say that the wheel turns at least 263.2 radians during the given time interval.
Note: If we were given the values for mass and radius, we could solve for alpha and then calculate the exact angular displacement.
Related to Rotational motion: Find angular displacement when rotation speed is changing
1. What is rotational motion?
Rotational motion is the movement of an object around an axis or center point. It can be described in terms of angular displacement, velocity, and acceleration.
2. How is angular displacement calculated?
Angular displacement is calculated by taking the change in angle of an object as it rotates around a fixed axis. It is measured in radians or degrees.
3. What is the relationship between rotational speed and angular displacement?
The relationship between rotational speed and angular displacement is directly proportional. This means that as the rotational speed increases, the angular displacement also increases.
4. How does changing rotational speed affect angular displacement?
Changing rotational speed affects angular displacement by altering the rate at which the object rotates and therefore, the amount of angle it covers in a given period of time.
5. What is the difference between angular displacement and linear displacement?
Angular displacement refers to the change in angle of an object as it rotates, while linear displacement refers to the change in position of an object in a straight line. Angular displacement is measured in radians or degrees, while linear displacement is measured in meters or feet.
