Rotational Motion Homework: Mass 12 kg Rod, Pivot Friction-Free
The discussion revolves around solving a physics problem involving a uniform rod of mass 12 kg and length 1.0 m, pivoted at one end and falling under gravity. Participants suggest using the moment of inertia and Newton's second law to find the angular acceleration and speed of the rod at specific points during its motion. The moment of inertia can be calculated using the rod's geometry without needing to know the torque. A hint is provided to analyze the forces acting on the rod at a displacement from its equilibrium position to determine the torque. The conversation emphasizes the importance of understanding the relationships between torque, angular acceleration, and moment of inertia in rotational motion.
robbyrandhawa
Consider a uniform rod of mass 12 kg and length 1.0 m. At its end, the rod is attached to a fixed, fricition free pivot. initially the rod is balanced vertically abbove the pivot and begins to fall (from rest) as shown. Determine
a) the angual acceleration of the rod as it passes through the horizontal at B
b) the angual speed of the rod as it passes throught the vertical at C
i want to say...
w=wo + at
θ = wot + 0.5at^2
I have absolutely no clue how to start this off... what i wanted to do was find some information at point A such as the angle it makes there or the velocity
then from this information.. find angular acceleration at B for partt a.
then use the info from a to find angular speed at C
but i have no clue how to start this off.. if any1 can help me start it off it will be a big help!
I=mr^2 and Torque=Ia(angular)… you saying to use these. If i find I(inertia) at point a then i use that and find angular acceleration at B? is that what your hinting towards?
Hello, yes, that is what I mean. Consider that rod is rotating about it's end.
i just realized how can i find inertia (I) at a because i don't know what Torque is ….
i worked something out and both torque and I were 12 :S that looks wrong
You don't need to know the torque to find the moment of inertia of the rod; it's solely a function of the geometry and the mass distribution. The moment of inertia of a uniform thin rod about an axis through its end is well known. (Hint: you can either look this up or use elementary calculus.)
For determining the torque, you might wish to consider the rod at a displacement ##\theta## from it's initial equilibrium position, and then consider the forces acting upon it.
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
