Roundoff error - double precision is not enough
  • Thread starter Thread starter coccoinomane
    Error Precision
The discussion centers on the challenges of computing functions involving sine and cosine when both variables approach zero, leading to significant roundoff errors in double precision calculations. The user has successfully reformulated one function as a spherical Bessel function, which can be accurately computed using the GNU Scientific Library. However, they still face precision issues with their integral calculations and seek advice on high-precision C++ libraries. Suggestions include using power series expansions for sine and cosine to improve accuracy for small values of rx. The user acknowledges improvements in their results but remains concerned about potential precision loss in their computations.
coccoinomane
Hi everybody!
I kindly request your help. I have to compute functions like
\frac{ \sin (r x) - r x \cos (r x)}{r^3}
(primitive function of x sin(rx) )
or
\frac{ -r x (120 - 20 r^2 x^2 + r^4 x^4) cos(r x) + <br /> 5 (24 - 12 r^2 x^2 + r^4 x^4) \sin(r x)}{r^7}
(primitive function of x^5 sin(rx) )
when both r and x varies.
The problem with these functions is that the sin and cos factors are very similar to each other when x approaches zero. This is a big issue: double precision is not enough to compute the difference because of roundoff errors or simply because 14-15 digits are not enough to distinguish the two factors.
I kind of solved the problem for the first function. In fact, I could express it up to a factor as the first order spherical bessel function:
j1(x) = \frac{\sin(x)/x - \cos(x)}{x},
which is well computed in the GNU Scientific Library.
I need to calculate those functions to solve the integral I discussed in https://www.physicsforums.com/showthread.php?p=2028408#post2028408 and that uart helped me to solve.
Thank you very much for any suggestion,
Guido
Mathematics news on Phys.org
I forgot to mention that I need to compute the functions for a very large array of "r" values from within a C++ program. Thus, pasting the result from Mathematica is not helpful :)
Cheers,
Guido
The problem you have is essentially in the numerators of your expressions when rx is small. I suggest that you (on paper) use the power series for sin and cos, where the terms in rx cancel for your expressions. Programming in the cubic term and possibly the fifth order (depending on how precise you want it) should be sufficient for small rx.
or use any of the high precision c++ libraries...
Hi mathman, thank you for your answer. You are right indeed.
I tried to expand the sine & cosine as my first approach, but I made a stupid mistake in the calculation of the coefficients and I got wrong results. I re-did everything and now I get results as precise as 10^-6. Thank you!
@NoDoubts
Could you please point me to some of these libraries?
However, I am not sure it would help. Unless they have computed the same function I need, i.e.
<br /> \int_{0}^{k_0} k^{n} \frac{sin{kr}}{kr} dk<br />
(and GSL doesn't have), I am afraid the precision problem would pop up again. However precise can the library be, it boils down to a difference between very small numbers --> loss of precision.
Cheers,
Guido
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
