RRC Circuit - Capacitor Charge?
The discussion revolves around calculating the charge on a capacitor in an RRC circuit with two batteries and resistors. The initial attempt to use the formula Q = C*(V1 + V2) was incorrect due to the unequal battery voltages. It is emphasized that after closing the switch for a long time, the circuit reaches a steady state where the capacitor will have a constant voltage and no current flows through it. To find the voltage across the capacitor, applying Kirchhoff's voltage laws to the circuit loop is recommended. This approach leads to the correct calculation of the capacitor's charge.
bchubz
http://www.webassign.net/hrw/hrw7_27-76.gif
The circuit in the figure shows a capacitor, two ideal batteries, two resistors, and a switch S. Initially S has been open for a long time. If it is then closed for a long time, what is the charge (in Coulombs) on the capacitor? Assume that the batteries have emfs of ε1 = 1.50 V and ε2 = 8.10 V and that C = 7.00 μF, R1 = 0.18 Ω, R2 = 0.44 Ω.
Kirchoff's voltage laws
I tried C*(V1+V2) = Q. This isn't correct, and not exactly sure where to go next.
Because the two battery voltages are unequal, there will be a steady-state current in the long term. After stabilization, there will be no current through the cap, and a constant voltage across the cap. You can find that voltage by writing a loop equation around the outer loop to find the loop current, and then calculate what the voltages are at points going around the loop.
Great thanks! I just needed a little nudge.
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
