MHB S3TAR3H's question at Yahoo Answers regarding marginal revenue
  • Thread starter Thread starter MarkFL
    Marginal
The discussion centers on solving a problem involving marginal revenue and production functions related to a factory employing workers. The factory's output and revenue functions are defined, and calculations are made for a scenario with 10 workers. The price per unit is determined to be approximately $6.25, while the marginal revenue is calculated at about $4.87. Additionally, the marginal-revenue product is estimated to be around $3313.95, indicating the revenue increase from hiring an additional worker. The calculations are verified by comparing the estimated change in revenue with the actual change when increasing the workforce.
MarkFL
MHB
Here is the question:
Need help with derivatives please!?
All answers involve a unit of dollars, so you must enter your answers accurate to two decimal places!
A factory owner who employes m workers finds that they produce
q= 1.8m(1.8m+18)^3/2 units of product per day.
The total revenue R in dollars is
R=1312q / (24660+5q)^1/2
(a) From the fact that
revenue =(price per unit)*(number of units)
it follows that
R=(price per unit)*q
So when there are 10 workers, the price per unit is ? dollars.
(b) When there are 10 workers, the marginal revenue is ? dollars/(one unit of product).
(c) The marginal-revenue product is defined as the rate of change of revenue with respect to the number of employees. Therefore,
marginal-revenue product=dR/dm
If q and R are given as above then, when m= 10, the marginal-revenue product is ? dollars/(one worker). This means that if employee number 11 is hired, revenue will increase by approximately ? dollars per day.
I tried substituting 10 for m and my answer was 3888 which is wrong :(
also I know that the marginal revenue is the derivative of the revenue function but i still can't seem to find the right answer :(
I have posted a link there to this thread so the OP can view my work.
Mathematics news on Phys.org
Hello S3TAR3H,
Let's work this problem using parameters rather than numbers, so that we then have formulas we can use in the future for similar problems, as I have see this same problem type posted many times in my years on math help forums.
The number of units produced by $m$ workers is:
$$q(m)=am(am+b)^{\frac{3}{2}}$$
The total revenue from $q$ units is:
$$R(q)=\frac{cq}{(dq+e)^{\frac{1}{2}}}$$
where $$0<a,b,c,d,e$$.
Given that revenue is price per unit time units sold, then price per unit $p$ is:
(1) $$p=\frac{R}{q}=\frac{c}{(dq+e)^{\frac{1}{2}}}$$
Find $$\frac{dR}{dq}$$
(2) $$\frac{dR}{dq}=\frac{(dq+e)^{\frac{1}{2}}(c)-(cq)\left(\frac{1}{2}(dq+e)^{-\frac{1}{2}}(d) \right)}{\left((dq+e)^{\frac{1}{2}} \right)^2}=\frac{c(dq+2e)}{2(dq+e)^{\frac{3}{2}}}$$
Find $$\frac{dR}{dm}$$.
Using the chain rule, we may state:
$$\frac{dR}{dm}=\frac{dR}{dq}\cdot\frac{dq}{dm}$$
$$\frac{dq}{dm}=(am)\left(\frac{3}{2}(am+b)^{\frac{1}{2}}(a) \right)+(a)\left((am+b)^{\frac{3}{2}} \right)=a(am+b)^{\frac{1}{2}}\left(\frac{5}{2}am+b \right)$$
And so we have:
(3) $$\frac{dR}{dm}=\left(\frac{c(dq+2e)}{2(dq+e)^{\frac{3}{2}}} \right)\left(a(am+b)^{\frac{1}{2}}\left(\frac{5}{2}am+b \right) \right)$$
Next, we want to identify the data given in this particular problem:
$$a=1.8,\,b=18,\,c=1312,\,d=5,\,e=24660$$
To answer the questions, we need to find the value of $q$, when $m=10$:
$$q(10)=18(18+18)^{\frac{3}{2}}=18\cdot6^3=3888$$
a) Using formula (1), we find the price per unit $p$ is:
$$p=\frac{1312}{(5(3888)+24660)^{\frac{1}{2}}}=\frac{656}{105}$$
To two decimal places of accuracy, this is:
$$p\approx6.25$$
b) Using formula (2), we find the marginal revenue is:
$$\frac{dR}{dq}=\frac{1312\left(5(3888)+2(24660) \right)}{2\left(5(3888)+24660 \right)^{\frac{3}{2}}}=\frac{125296}{25725}$$
$$\frac{dR}{dq}\approx4.87$$
c) Using formula (3), we find the marginal-revenue product is:
$$\frac{dR}{dm}=\frac{125296}{25725}\left(\frac{9}{5}\left(\frac{9}{5}(10)+18 \right)^{\frac{1}{2}}\left(\frac{5}{2}\left(\frac{9}{5}(10) \right)+18 \right) \right)=\frac{20297952}{6125}$$
$$\frac{dR}{dm}\approx3313.95$$
As a check, we can find compute the change in revenue over the change in the number of workers when going from 10 to 11 workers, and compare it with the estimate we just found.
$$\frac{\Delta R}{\Delta m}=\frac{R(q(11))-R(q(10))}{11-10}=R(q(11))-R(q(10))$$
Now, we need to compute:
$$q(11)=\frac{99}{5}\left(\frac{99}{5}+18 \right)^{\frac{3}{2}}=\frac{56133}{25}\sqrt{\frac{21}{5}}$$
And so we find:
$$\frac{\Delta R}{\Delta m}=R\left(\frac{56133}{25}\sqrt{\frac{21}{5}} \right)-R(3888)\approx27651.8824207754-\frac{850176}{35}\approx3361.13956363254$$
Compare this with the approximation we found:
$$\frac{\Delta R}{\Delta m}\approx\frac{20297952}{6125}\approx3313.95134693878$$
We find our estimate from part c) is close to the actual value, in fact there is about a 1.4% difference.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
